ignition key was stuck
Old Sep 26, 2013 | 09:51 PM
nlhummer's Avatar
Default ignition key was stuck
So I could not take my key out anymore when I put the car in park and shut it off. Once in a blue moon it would still do it but most times it did not.
So I did some research here and found out it would most likely be one of 2 things.1 a bad ignition switch.
Bought a new one and switched it out, at least I tried but missed a small screw so went to a mechanic for help. We switched the the ignition switch out but that was not it and he was done. So I took it took the next place and it was indeed the number two thing.
I had two broken wires underneath the transmission shifter. Apparently the dangle and over time they break Pretty easy fix once the issue was found.
Posting this so others know what to do if it happens to them and I am sure it is gonna happen.
Last year I had another wire break under the car that shut down the AC.
Some things in these trucks are a stupid design
Old Sep 27, 2013 | 07:49 AM
calif phil's Avatar
Good tip!
Old Sep 27, 2013 | 11:08 PM
ISP's Avatar
ISP
thanks for sharing!
nncanfarelli
Aug 4, 2019 09:27 PM
hummerhonduras
42
Sep 19, 2012 11:49 AM
lbzvegas082
Jul 21, 2010 07:17 PM
ezspirit
Jun 29, 2009 07:13 AM
doyleh3
Apr 2, 2008 10:01 PM
