i work for hummer
Old Mar 2, 2008 | 01:29 PM
Lampooner's Avatar
Default RE: i work for hummer
Thanks to all who responded to hitch question.
At the risk of answering my own question, the solution seems to beas follows:
Buy the Equal-i-zer weight distributing hitch, which is available without a shank, the piece that goes into the receiver on H2. Also order the shank which gives a 9" drop and a 12" extension. This will clear under the tire and with the hitch itself extending beyond the shank arm, it will clear the tire itself.
Found this out from a person on RV.net. He tows the same trailer I have with an H2, very helpful fellow.
I have also ordered an electric jack for front of trailer.
Thanks again.[align=right]
[/align]
Old Mar 3, 2008 | 07:49 AM
calif phil's Avatar
Have you looked at the Alumistinger ball mounts. I have one and really like it. Looks good and doesn't weigh much.
Old Mar 4, 2008 | 08:18 AM
BMJM100's Avatar
Calif phil, those look nice, can they handle the weight? I may have to pick one up myself! Thanks!
Old Mar 4, 2008 | 09:56 AM
TheGunnyRet's Avatar
rykid, welcome aboard here is some information I would like to ask for on a 2007.5 H3:
P/N and type/model Alternator.
P/N and size of the throttle body.
P/N and size of the MAS/MAF Sensor.
Bolt Pattern # of boltsfor the front axle pumpkin i.e. 9" or 8.5.
Bolt Pattern # of bolts for the rear axle pumpkin.
Battery P/N andsize L-W-H i.e. 34T, 35T, D75/25?
Spark Plug type/P/N
Cam Shaft (s) Specs int and exh lift
Torque specs for the Valve Cover.
Fuel Injector type (Mutec, Delphi, Seimans etc...)and Size.
Here are some questions for the H3 Alpha Crowd.
P/N and Type/Model Alternator.
H3 Alpha Air Filter Size= L-W-H " and P/N for those who have an Alpha.
5.3 V8 type is it a LS series Gen III or IV or LS1?
Cam Specs and stock Rocker arm ratio i.e. 1.6, 1.7, 1.8 ?
Throttle Body size and P/N.
Coils, Coil on Plug P/N and type i.e Delco style unit for the Delphi System.
Intake Mainfold P/N and is it a LS1 or LS6 type.
That's it for now Thanks.
Old Mar 4, 2008 | 10:47 AM
rykid's Avatar
to get you the correct part numbers i need a vin number
Old Mar 4, 2008 | 11:50 AM
Well I am here in Iraq, can I suggest you take it off of one in the lot? i know the H3 3.7 would be an 08 but i haven't read that there are any specific changes from the two model years. Same suggestion for the Alpha, if you can't do that I guess I will have to wait or if anyone on here is willing to provide it, it would be up to them.
Old Mar 4, 2008 | 05:23 PM
calif phil's Avatar
BMJM100 Yes the alumistinger I have is good for 10,000 Lbs I think. I was skeptical at first but it is very well made and it sure looks strong. Made In USA too.
Old Mar 5, 2008 | 11:31 AM
rykid's Avatar
i just PMed someone for the alpha he sent me his vin. im sure he will post all the info
Old Mar 5, 2008 | 04:34 PM
alphadogg's Avatar
I sent my vin# to rykid and here's what he sent me back:
OK SO FAR HERE IS WHAT I FOUND FOR YOU i can fax you all kinds of things with pics if you need it
this fits your h3 and these parts are by your vin.
intake manifold 12580420
alt 145 amp 15905872
air filter (dont stock one yet so i can measure) 15942429
engine says 8cyl 5.3l sfi ho
throtle body 12580760
plugs 12571164 the short ac delco number is 41-985
coils they have 2 designs
1st design *square shaped coil 12570616
2nd design is a round shaped..12573190
Old Mar 7, 2008 | 09:08 AM
rykid's Avatar
THOSE PARTS ARE FOR THE ALPHA!!!!
