I did the torsion bar adjust and have a question
Old May 25, 2007 | 07:11 AM
ajhagerman's Avatar
Default I did the torsion bar adjust and have a question
Okay guys, I did the torsion bar adjustment in order to put 35's on this weekend....it has a bit of a bounce in the front now...is this normal? I dont know how many turns it took to level the truck out because a friend did it before the front end alignment...but it is level now. Another question, Im not a car idiot but I have never messed with such a componet...what exactly do these do? everyone says it wont effect anything by adjusting, but I deal with GM on a daily basis and they just dont do something for no reason...Im sure there were atleast 4 engineers that came up with the ride height.
Thanks!
Old May 25, 2007 | 07:15 AM
dilo2001gt's Avatar
Default RE: I did the torsion bar adjust and have a question
i would get new front shock 2in bigger
Old May 25, 2007 | 08:15 AM
Dennis's Avatar
All I can tell you is I won't do mine...What you did by cranking on the T-bars was stiffen up the front springs, which is the torsion bars..so yes you will get a bouncier ride now...
Old May 25, 2007 | 10:16 PM
Gunner_45's Avatar
Hi AJ,
Use the search function here on the forumfor Cognito or Bilstein......They have a product that will
take care of your ride problem........Multiple threads on the topic............
(I'd give you the info/links direct, but I'm on a stupid laptop with a persnickety keyboard and "pointing devise")
****.....took five minutes just to write that.....jeez.....[:@]
Old Sep 29, 2007 | 08:30 PM
hilljob26's Avatar
gunners the man
Old Sep 29, 2007 | 11:03 PM
tomp's Avatar
Dennis is incorrect. It does not sitffen or increase spring rate when you crank the TBs. It only adjusts the ride height. The reason it bounces more is because you reduce the amount of droop because the shocks are limiting the droop downward. Get Cognito extended shocks for H3 and you will be all set: http://cognitomotorsports.com/store/Hummer_H3.html
Old Oct 4, 2007 | 06:35 PM
hilljob26's Avatar
i made some shock extenders for mine,just because i am a tight waud,but after these shocks go,i will probably buy the cognitos,just because thats the in thing
Old Nov 6, 2007 | 12:47 PM
H0useofz's Avatar
sorry for this noob question but was wondering,can the torshion bars ware out? why i ask this is i have a 9in lifted hummer fabtec lift running 38. and one day noticed my truck was cockeyed. took it to the dealer and said they need to replace the torshion bar as it was wareing out.
k9guy
Jan 16, 2012 12:28 AM
jej721
Mar 18, 2010 09:01 PM
psych0
Mar 10, 2010 09:17 PM
bmbenear
Nov 20, 2008 10:20 PM
Heysdad
Aug 11, 2007 10:47 PM
