Hummer H3 3.7 Ring and Pinion ,,,, Please help!
Old Mar 13, 2018 | 11:52 AM
T REX's Avatar
Default Hummer H3 3.7 Ring and Pinion ,,,, Please help!
I need help on getting the correct Rear Ring and Pinion for my Hummer H3 3.7 X with rear Diff lock,
The research I have done is that the rear Ring is a 8.5 inch with a 4.56 ratio and the front Ring is a 7.5 inch with a 4.56 Ratio for the 3.7 I-5 engine
Unfortunately I ordered the 7.5 inch with the 4.56 Ratio thinking it would fit on my rear diff. BIG Mistake.
So now I realize I need the 8.5 Inch Ring for my rear diff, So am looking to order again but see so many Ratio's [example 4.10 , 3.80 etc] available on the 8.5 inch Ring?
My question is , does the ratio of the gear and pinion change the actual size of the ring and pinion ? as im worried it wont fit and I have another useless part
Any experience and information would really be appreciated?
Also Ive found the part part but it only says for the H3T is there a difference in the ring and pinion between the H3 and the H3T?
Kindest thanks
Johan
Old Mar 13, 2018 | 01:19 PM
I5 H3s all have 4:56 ratios, if you already ordered a 4:56 for the front, you will need a 4:56 for the rear. Alphas have 4:10 ratios, same size rings as the I5s.
To answer your question, an 8.5" ring is and 8.5" ring. A ring that size can only squeeze so many teeth on it.
Those other ratios are for other GMs using an 8.5" ring, like S-10 pick ups and Jimmys etc...
Old Mar 13, 2018 | 01:20 PM
happythree's Avatar
both gotta be same ratio or you wont go anywhere. 456
Old Mar 14, 2018 | 02:24 AM
T REX's Avatar
Ok Great Thanks Very Much ,
autobots
Feb 21, 2017 03:09 PM
Dugrobin
Jan 29, 2015 09:53 PM
elkgrunt
Oct 18, 2013 06:29 AM
bankauto888
Apr 4, 2011 11:07 PM
theBroken
Feb 20, 2010 10:20 AM
