ring and pinion
Old Oct 17, 2013 | 06:12 AM
elkgrunt's Avatar
Default ring and pinion
Has anybody changed the ring and pinion in their H2? If so what gear ratio would you suggest for 38 to 40 inch tires? What is the stock ratio?
Old Oct 17, 2013 | 11:33 AM
fyr145's Avatar
Default Gear Ratios
Originally Posted by elkgrunt
............. What is the stock ratio?
H2 Axle Ratios
2009: 3.73
2003-2008: 4.10
Old Oct 17, 2013 | 07:25 PM
elkgrunt's Avatar
Thank you, I thought they were 4.10.What would you recommend for 38'' or 40'' tires?
Old Oct 17, 2013 | 07:31 PM
fyr145's Avatar
Default gears
It would depend on what you want more..........
Typically,
Lower gears give you good start up speed off the line but top out thus limiting your higher speeds down the road.
Higher gears are slow to start off with at the beginning, but give you more top end speed.
Running bigger tires requires more torque on the bottom end to get them moving with any true need of power.
You cannot have both.
Here is a gear finder site. Use it for some ideas on what you might need.
http://www.crawlpedia.com/gear_ratio_calculator.htm
Old Oct 18, 2013 | 06:29 AM
elkgrunt's Avatar
Thank you so much.
autobots
Feb 21, 2017 03:09 PM
screaminhd
Jun 11, 2013 03:33 AM
bankauto888
Apr 4, 2011 11:07 PM
randolphburgos
Nov 10, 2010 05:15 PM
theBroken
Feb 20, 2010 10:20 AM
