Hummer h2-sut in the sand
Old May 28, 2013 | 10:18 PM
JCsh2's Avatar
Default Hummer h2-sut in the sand
How good is your hummer in beach sand? Thinking of tagging my 06 h2 sut for surf fishing but concerned about getting stuck in the deeper sand.Any input on this? Thanks..and it's stock 17 in wheels and a/t tires
Old May 29, 2013 | 05:20 AM
Bunger's Avatar
Two things about running in sand:
1) air down your tires to about 15 lbs for soft loose sand.
2) keep momentum. steady on the throttle but if you start spinning, STOP. then BACK OUT of the spot. if you don't you will dig yourself into a hole.
Old May 29, 2013 | 01:17 PM
JCsh2's Avatar
Ive been on the beach before many many times in my jeep wrangler and full size bronco run them both in lo gear no problem just not my hummer yet was cocerned about the weight of it more than anything didnt want to get out there and look dumb all stuck needing to be pulled out and giving my hummer a bad name like mall crawler lol you know? Well going to give it a shot thanks for yourinput.Oh whats the best should I run it in lo or high gear in sand?
Old May 29, 2013 | 01:44 PM
Bunger's Avatar
I've only run in Hi.
Everything I have read about sand & dunes running says to stay away from Low.
The H2 shouldn't handle much different than the full size Bronco.
atikot
Dec 14, 2011 03:18 PM
Gunner_45
May 9, 2007 01:09 PM
Greenblade
Apr 24, 2007 07:26 PM
qatar
25
Jan 18, 2007 09:54 PM
usmcman001
Jun 11, 2006 02:04 AM
