Hummer H2 Interior Lights
Old Dec 16, 2016 | 11:32 AM
Sooner1's Avatar
Default Hummer H2 Interior Lights
I have a few random interior backlights that do not work. For instance, the backlight that shows the seat heat that is located on the drivers door doesn't work. The seat heater works and the 3 lights indicating the level of heat works, just not the backlight showing the seat. Passenger door, all is fine. In addition, a couple of the backlights on the steering wheel do not work. Such as, the "information" button and the volume buttons. The others on the steering wheel work fine. Are these "backlights" replaceable individually? If so, how? I can probably figure out the door, but the steering wheel I am not sure. I thought I read where you can actually get bulbs for these to change them to different colors, but I may be wrong. Anyone have any information around the oddity of them not working and/or changing them out?
Old Dec 18, 2016 | 07:18 PM
twinmill28's Avatar
Yup, among the list of little annoying things that no longer work on my H2, many of those little freaking lights have gone out. I read a post somewhere that if you're handy on a soldering iron you can remove the bulbs and replace with an led equivalent. Not sure what that equivalent would be though.
I've seen that you can carefully remove the buttons in the steering wheel by prying them out, haven't tried that yet.
Pretty sure all of the buttons still available for purchase to just replace the entire assembly, but I like the idea of soldering in the LED's.
These lights being out annoy me, but not to the point of dismantling the dash, steering wheel and door panels to fix everything. I'm kind of hoping they all just finish burning out so I can imagine they never had lights--but that's not how it will work, just enough stay lit to upset the balance.
Old Dec 18, 2016 | 07:34 PM
NoSpoon's Avatar
Steering wheel buttons/lights are easy. Just replace the whole button. They are about $15-$20 each and take 5 minutes to change. Just slide a pick down next to the button and pull it out, unplug it, plug in new one and push it back in.
I replaced bulbs in my AC controls with these:
5mm ? High Brightness White LED #276-0017 By RadioShack | eBay
They may be able to replace the lights that you have out. Just get a good small soldering iron.
Good Luck!!!
Old Dec 19, 2016 | 11:56 AM
LoJac963's Avatar
I've replaced every light in my interior with LED. They are all easily done with a good soldering iron and good solder wick.
I really wish I took more pictures of this process but I didn't.
Here's a few pics:
Changed seat backlights to red LED's
I can't upload any other pics to photobucket for some reason but they are standard LEDs.
Old Dec 20, 2016 | 10:27 AM
Sooner1's Avatar
Does anyone have a link to the steering wheel buttons and LEDs for purchasing?
Old Dec 20, 2016 | 06:42 PM
Rokoneer's Avatar
GM Chevrolet Steering Wheel buttons switches control New w Blue LED's 4pc Dorman | eBay
http://www.ebay.com/itm/GM-Chevrolet...lVLfI9&vxp=mtr
Old Jan 12, 2017 | 09:42 PM
dontheo55's Avatar
I was just checking this out on YouTube and saw two methods. One to replace the bulb the other, requires soldering, and repairs it but is quite inexpensive. Bulbs can also be purchased off eBay.
ff2024
Nov 4, 2023 09:39 PM
jamdd2005
Aug 12, 2011 11:30 AM
pimp1913
Jul 31, 2008 05:33 PM
GreenH3
Jan 21, 2008 05:51 PM
z
May 25, 2007 01:58 AM
