Hummer H2 Differential lubricant
Old Mar 10, 2011 | 03:47 AM
Random-Hero-'s Avatar
Default Hummer H2 Differential lubricant
Hey everyone, I'm going to be replacing the fluid in my front and rear differentials this weekend, and it says to use 75W-90 Synthetic Axle Lubricant in the manual, use either the GM stuff or a 75W-90 Synthetic Axle Lubricant that "meets GM Specification 9986115."
I was looking at the AMSOIL Severe Gear 75W-90:
http://www.amsoil.com/storefront/svg.aspx
However I'm not sure if it meets GM specs 9986115.
Has anyone else had this issue? Are there any other fluids from other brands I could use? Any input would be great, thanks!
Old Mar 10, 2011 | 12:42 PM
No more Jeeps's Avatar
I would think the Amsoil would meet or beat the GM oil. When I had mine changed at the dealership they did not add any modifiers to the oil for the posi limited slip. Not sure if the Amsoil is the same. On my Toyota Land cruiser has the same thing done at the dealer. When I got it back it would clunk around corners. Dealer added the modifier and the noise went away. MAy not hurt to add some while your changing the oil.
Old Mar 12, 2011 | 08:30 AM
calif phil's Avatar
The Amsoil will work fine. It is great stuff. The GM fluid is also great. Made for GM by Mobil so it's probably Mobil 1.
Old Mar 23, 2011 | 10:51 AM
JDTDBD's Avatar
I used Mobil-1 75/90 Synthetic gear oil. been like 6,000 miles and no issues. Did it myself and saved HUNDREDS vs. dealership. H2 has its own fill and drain plugs. Took like 5 min a diff.
motley1987
Jan 28, 2014 07:57 PM
danist
Aug 24, 2007 07:18 PM
HingHum
Jun 13, 2007 07:12 PM
2luke2
Mar 30, 2007 10:22 AM
HummerGuy
20
Dec 22, 2006 02:14 PM
