Hummer h2 accelerator pedal vibrates
Old Apr 30, 2017 | 11:59 AM
Samir H2's Avatar
It's not the drive shaft. It feels like something might be lose between the engine and the pedals. I'm gonna get under the car soon and have a good look around. Possibly the heat shield or something around there. Il keep you updated if I find anything.
Old Apr 30, 2017 | 02:15 PM
mcioci's Avatar
Originally Posted by Samir H2
It happens a little more noticeably at higher speeds. It doesn't do it in park either for me. I've tried it in N at high speed and it doesn't do it. It happens all the time over 30mph. As soon as i release the pedal, I feel the vibration with my foot. Never while accelerating, only when I let off. It only lasts about a second
I feel it while slowly going past 30mph and feel it at 40 mph. Once I go past 40 the vibration stops.
Old May 1, 2017 | 03:20 PM
LennyLexx's Avatar
Exhaust vibration heat shield plates can carry through the frame and resonate in places. Check if any exhaust pipe or muffler from engine to the back is lose. I have an audible vibration from my H2 exhaust I can hear on acceleration. It's the exhaust cause I had the exhaust on my excursion switched over to dual and that was when I heard the same noise. So in my case it's from either the muffler or pipes.
Old Jun 10, 2017 | 11:02 AM
Samir H2's Avatar
Originally Posted by mcioci
I also have an 05 with the same issue. Ive had this issue since truck hit 50k miles. I am now at 89k miles. I just recently replaced the torque converter while fixing rear main seal but that did not help this vibration. I get it bet 30-40 mph. Its not the tires nor the rotors since I've changed both since I hit 50k miles.
Finally I found the problem. While driving the other day I broke a cv joint (car only has 21000 miles). I managed to get the it on a ramp and realized the bolt holding the top of the diff in place was missing. The vibration I'm guessing was just the lose bolt and it finally losened all the way or snapped off taking my cv joint with it. I was only traveling at a low speed so I was lucky nothing else happened. I've put a new bolt in and tightened everything up and now no more vibration. I'm getting a small cracking noise when hard breaking or turning at low speeds. The bottom diff mount doesn't look so good so that's my next job but I'm nearly positive it will solve my problems.
Will update you all once I've changed the diff mount.
4u33er
Jun 6, 2012 09:41 AM
pcremodel
Aug 24, 2011 08:27 AM
garyuk
Feb 10, 2009 05:47 PM
AMG55
Apr 15, 2008 11:32 PM
HummerGuy
Aug 9, 2006 11:09 AM
