How long before your 1st "time to change the oil" warning?
Old Mar 4, 2008 | 08:43 PM
Evadd's Avatar
Default RE: How long before your 1st "time to change the oil" warning?
whenever i buy a new vehicle i do the first oil change at about 100 miles (yes, one hundred). if you do it yourself, you'll likely see the oil shimmering a silver color with countless tiny metal shards left over from the machining process. i don't like to have those metal bits circulating the engine for a few thousand miles.
Old Mar 7, 2008 | 02:11 PM
Steve #1's Avatar
ORIGINAL: TheGunnyRet
The system is designed or programmed to5k to 15k on your oil. If I think what I think it is on how it does this, we had this type of monitor when I was in the Marines in Okinawa years ago. You ran a probe down the dip stick tube and the hand held device would analyze the oil and tell you if it needed changing. I believe it monitors metal, sulfur, water and even fuelcontent in the oil. But I bet the one in the H3only does metal (I'm guessing), I would send your oil to an oil analysis program if you really want to know about your oil.
http://www.worldlube.com/analyze.html
http://www.oaitesting.com/
http://www.polarislabs1.com/index.htm
The GM oil life system (GMOLS)uses an algorithm based on crank shaft revolutions and temperature.
Old Mar 8, 2008 | 03:21 PM
TheGunnyRet's Avatar
Then if thats the case if you deviate from the oem recommended weight your oil change indicated by the formula can be off and then also if you use a synthetic you could be wasting your money by changing your oil to soon. And Alsothen its basically another "Idiot Indicator" so you will have to change your oil eventually by having some kind of warning torture you untill you do.
Old Mar 8, 2008 | 06:49 PM
dmurdock's Avatar
After researching how the OLS works I think I'll wait for the warning before changing the oil.
Old Mar 9, 2008 | 10:40 AM
sattv's Avatar
The Dealer just changed mine at 6500 no questions asked.....I asked them what is in it from the factory? they replied conventional oil............WOW?
carid
Dec 3, 2014 08:40 AM
Geraldo
Mar 26, 2011 01:16 PM
RealJeep
Jun 17, 2008 10:16 PM
Bajadreamers
18
Jun 16, 2008 02:10 AM
scrming
Sep 12, 2007 04:35 PM
