How to get a 4l80e to work right with carb motor
Old May 18, 2016 | 09:55 AM
djbeck88@gmail.com's Avatar
Default How to get a 4l80e to work right with carb motor
Looking at putting a 383 stroker in a 96 h1. Right now it has a 4l80e trans and a 350. The guy I'm doing it for doesn't want to dramas swap or big block it. He is pretty set on a 383. What I need to know, is what will be needed for the transmission to work properly. If I'll need a full computer set up such as TCI's Ez TCI or just a TV cable up to the carb. Any help would be appreciated.
Old May 18, 2016 | 05:34 PM
Ian Ward's Avatar
I would go with a P400. Big dog offroad is a AM General Gep / Gtp dealer and can order all factory parts.You can get a amg p400 & amg factory wiring harness. Will need to also replace the top fuel tank plate assuming you have a gasser now.
Last edited by Ian Ward; May 18, 2016 at 05:35 PM. Reason: fat fingered the spelling
Old May 18, 2016 | 05:40 PM
Ian Ward's Avatar
You would also meed a new ecm to do the p400. The diesel p400 uses the same 4l80e trans. I beleive its actually a version of the 4L85e that is in newer hummers.
Old May 18, 2016 | 05:44 PM
It's a gas motor now. And he wants to stay with a gas motor. He wants to put a Chevy 383 stroker motor in it. I need to know what is needed to keep the trans shifting correctly.
Old May 18, 2016 | 05:45 PM
Damn fat finger ed the first post. He doesn't want to do a diesel swap.
Old May 19, 2016 | 12:36 PM
BigDogOffroad's Avatar
First off, I would suggest staying away from a carburated gasoline engine. I am not an expert on gas engines but one thing I know about this from personal experience is that carburators don't make sense on an off-road vehicle because as soon as you get the vehicle off camber or go up or down a steep grade your fuel system will shut down. So if you're going gas, go with fuel injection.
Old May 19, 2016 | 02:16 PM
Ian Ward's Avatar
Carb engines are temperamental and unsafe. They blow up and as my brother mentioned it will run out of fuel when unlevel. Go with a fuel injected engine. A 383 stroker can put out 450-550+ hp if tuned- the hummer and the hummer cooling system wont handle it ! Id go witha diesel or, if not a fuel injected engine for safety and reliability reasons.
Old May 24, 2016 | 01:11 PM
Ian Ward's Avatar
I would go with a factory gep 5.7 engine if you want it to stay a gasser. You can tune that and the cooling system up and use the factory amg wiring harness. I would not want to hack the vehicle harness apart. Thats a bucket of worms you dont want to open.
EnviroCon6
16
Mar 13, 2014 11:27 PM
Mx_racer_36
Jan 3, 2014 12:22 PM
hollywood_x
Oct 7, 2011 05:02 PM
socal
Oct 24, 2008 07:59 PM
RGERBER
Aug 11, 2008 01:46 PM
