How do you remove the rear spare tire carrier?
Old Aug 14, 2014 | 08:14 AM
RJ3607's Avatar
Default How do you remove the rear spare tire carrier?
Looking to remove my outside rear tire spare carrier. I would like to leave the actual tow hooks in place though. I want to take just the arm off while leaving the rest of the assembly on the vehicle. (tow hooks)
What do I need to do?
Old Aug 14, 2014 | 10:04 AM
ak47dennis's Avatar
1. Remove the spare
2. Losen and unbolt the passenger tow hook, you way want to have the wife or buddy help once the tow hook bolts are out the major part of the carrier will fall away. (like 75 lb.)
3. Losen and unbolt the drivers side hook and remove the small latch section.
4. Depending on if your truck came factory with the rear tire carrier from the factory will determine your next move. The trucks that had factory installed carriers will not be equipped with license lights. The trucks that someone added on the carrier will more then likely need the license plate bulbs reinstalled.
Old Aug 14, 2014 | 10:30 AM
RJ3607's Avatar
I'm wanting to keep the tow hooks in place though. I've seen people basically lift the swing arm out of the passenger tow hook while leaving the tow hook in place in the bumper. How do you do this??
Old Aug 14, 2014 | 11:51 AM
ak47dennis's Avatar
After your remove the tire carrier, you bolt your tow hooks back on.
Old Aug 15, 2014 | 02:35 PM
ant69's Avatar
After you remove the spare carrier you will see that the hooks are separate and go right back in the same spots.
Old Oct 20, 2014 | 09:31 AM
mattdillon's Avatar
I haven't looked yet, but where will you need to dis-connect the wiring that goes for the bulb on the license plate! my 03' didn't have one but the 08' came with it from the factory & I was just wondering! thanks!
Old Oct 20, 2014 | 12:58 PM
Thunder Cat's Avatar
the lic. plate light wire runs out the bumper & along the carrier to the center of the spare tire, I just unclipped the wire ties & bundled up the wire behind the plastic bumper cover... the newer style carriers the tow hooks are part of the assembly, unlike the '03 which you could reuse the hook without the carrier on.. & if you have an SUT like me, you need to figure out a new place to mount your licence plate & rig up the light some how
Attached Thumbnails How do you remove the rear spare tire carrier?-h2-20x10.jpg
Old Oct 20, 2014 | 03:36 PM
mattdillon's Avatar
Thanks Thunder Cat, Nice Looking Ride by the way! I Don't have the SUT but mine has a place to put the license plate on the back of the Hatch, just need to get the accessories to do it!
tharber
Jun 19, 2015 07:21 AM
Brianb
May 4, 2012 08:52 AM
s_c5519
Oct 27, 2009 03:15 AM
beachman
Jan 23, 2008 06:54 AM
danaw
May 1, 2007 12:32 AM
