How do release the parking brake?
Old Apr 9, 2015 | 12:55 AM
hum3r's Avatar
Default How do release the parking brake?
I'm doing brake work on my son's '07 H3 and I'm having a problem removing the rear rotor because the parking brakes are too snug, I pulled the parking brake release lever but it doesn't seem to release. I noticed this thing has an electronic parking brake sys that's automatically activated, is there a way of releasing it so I can remove the rear rotors? Thanks much for any helpful replies. This is my first time on this forum.
Old Apr 9, 2015 | 07:07 AM
RKSmith163's Avatar
The parking brakes on the H3 are completely manual. Maybe someone else will help you with the release issue. Good Luck Oh and by the way, welcome to the forum.
Old Apr 9, 2015 | 09:07 AM
Your parking brake is manual, not electronic. It is "stuck" because of dirt, corrosion and/or rust. Lube its moving parts with a spray lubricant (like CRC power lube... WD-40 is not a lube), NOT THE PADS, and press and release the parking brake pedal to work it free.
The H3 service manuals are free and online, search that out and see if any info in there helps.
Old Apr 9, 2015 | 05:15 PM
wfturner's Avatar
I'm sure you have this figured out by now, but . . .
I replaced my rear pads and one side was tough to get the old pads out. I thought it was the E-brake, but
it was a sticking caliper pin. It was rusted tight and hard to remove.
All fixed now.
Good luck with the repair
Old Apr 9, 2015 | 11:28 PM
hum3r's Avatar
Thanks Doc, you've been a big help. In addition to lubricating the moving parts, it also seems a lot simpler to loosen the cables adjusting nut (under the driver's door) to release the tension and disconnect the rear cables as well and reattach after the brake work, what's your thoughts on this proceedure?
Old Apr 10, 2015 | 08:43 AM
Sounds like a solid plan to me. Let us know how it works out.
Old Jun 1, 2015 | 07:32 AM
Arthur Kill's Avatar
...The H3 service manuals are free and online, search that out and see if any info in there helps.
Where?
Can you link or point me in that direction? I've been looking with no luck.
Also if you know, where can I find an illustrated parts manual?
Thanks!!
Old Jun 1, 2015 | 08:23 AM
wfturner's Avatar
Originally Posted by Arthur Kill
Where?
Thanks!!
here:
Free Hummer Repair Service Manuals
Old Jun 1, 2015 | 09:57 AM
atari800's Avatar
I cant seem to download any manuals from there.
*Although I only tried 2007 h2 and 2008 h3 - but nothing
EDIT
Nevermind, if I turn off all the ad blockers it goes further.
Wants me to take a survey to get manual
lucky19942001
Oct 24, 2019 12:41 PM
khoolhandz
Feb 19, 2018 05:31 PM
nelsonhood
Jun 25, 2013 10:12 PM
wfturner
19
Jun 23, 2011 07:49 AM
chsnprodigy
Jun 25, 2007 11:10 AM
