How do I install a Hella Light switch?
Old Mar 26, 2011 | 10:25 PM
Stonewall88's Avatar
Default How do I install a Hella Light switch?
I just recently bought a pair of Hella lights to mount to my roof rack. I have all wires and everything hooked up but i'm having problems figuring out how to mount the switch for the lights. I think the best way to do this is to place the switch in the already stock made holes that are on the lower part of the dash (the two dark colored circles that are between the rear wiper control and the aux plug ups). If anyone knows how to get to these holes or how to remove the lower part of the dash please let me know! Thanks!!!
Old Mar 26, 2011 | 10:36 PM
Draketh's Avatar
Pull the covers out of the two cig lights, put a finger in each one, and pull outwards. The bottom of the dash should pop right out, and then you can work your way around the sides.
One of the easiest dash's I've ever had to remove.
Old Mar 27, 2011 | 09:26 PM
deezy's Avatar
Yep, incredibly easy dash to work with. I installed LEDs in my vents in 15minutes,
and I have also used the holes you're talking about for light switches, I dont know about Hella switches but either way you can drill the hole bigger if need be.
Old Mar 28, 2011 | 10:19 AM
Draketh & deezy: Thanks for the reply. Worked very well and i was able to install the swtch perfectly!
Old Mar 28, 2011 | 10:57 AM
CARdiac's Avatar
Pictures please
Old Mar 28, 2011 | 07:16 PM
Here are a few pics
Also these and others of my H3 are under my pic gallary
Hummer Forums - Enthusiast Forum for Hummer Owners - Stonewall88's Album: 2008 H3 Build
Attached Thumbnails How do I install a Hella Light switch?-22.jpg   How do I install a Hella Light switch?-25.jpg   How do I install a Hella Light switch?-27.jpg
Old Mar 29, 2011 | 02:46 PM
tate2326's Avatar
that looks good. glad i found this thread..
any idea about changing the lights behind the fan ***** back there? mine is out behind my middle ****...
Old Mar 30, 2011 | 06:10 PM
tate
I couldn't tell ya. when i was messing around behind the dassh i didn't mess with those cause i was afraid of disconnecting something.
Old Apr 7, 2011 | 09:23 AM
HummerWorks's Avatar
I believe the ones in the dials are the same as in the 4x4 controls which are soldered micro led's.
If you have a steady hand and some free time you can de-solder the old ones and solder in new ones or even change the color.
nopavement
Jul 1, 2013 01:48 PM
Aussie H3
May 13, 2013 04:13 PM
Quiksilver-H3
30
Nov 21, 2010 06:46 PM
theBroken
Aug 6, 2009 06:08 PM
phazer42
Nov 30, 2008 12:43 PM
