How can you reduce the wind noise from the front doors?
Old Jan 12, 2013 | 12:42 PM
StormKatMan's Avatar
Default How can you reduce the wind noise from the front doors?
These front doors were not designed well to minimize wind noise. Is there any solution to cover the door seals so they are not exposed to the wind?
Any suggestion would be appreciated!
Old Jan 13, 2013 | 07:33 PM
Chief qc's Avatar
my h2 isent particulary noisy ?
wind deflectors that goes on top of the glass ?
Bushing replacement and door adjusted ?
Old Jan 14, 2013 | 10:59 AM
H2CANEPADESIGN's Avatar
May be a different issue. I had a ton of wind noise before I re-siliconed the strips on the side of the windsheild. they were making some serious noise.
Old Jan 14, 2013 | 11:05 AM
calif phil's Avatar
Same with mine. I ran a bead of black silicon down the pillar trim and it stopped the wind noise.
Old Jan 15, 2013 | 09:15 AM
I have received the same comments from others and will try that fix this week. Thank you for the response!
Old Jan 16, 2013 | 05:17 AM
LoJac963's Avatar
I agree, its probably the plastic trim on either side of the windshield. Most say to run a bead of silicone but I just picked up some of the cheap 2 sided sticky foam. I didn't want to glue them down with the silicone as I was going to start the wiring for my roof rack lights.
Double sided sticky foam took away the problem completely. Took a drive to Sedona and at 85mpg no rattle at all!
Old Jan 17, 2013 | 09:34 AM
I just bought some double sided tape. I will try that and I appreciate everyone's response!
Old Jan 17, 2013 | 07:38 PM
Man1nboat's Avatar
Make sur you completely remove the existing tape prior to installing the new tape. I used an exacto knife, pliers, nail polish remover with acetone, then isopropyl alcohol.
Old Jan 21, 2013 | 07:28 PM
honda400ex2003's Avatar
im hoping the glass replacement in my h2 this summer will help out my wind noise.
it is quite irritating sometimes haha i can hear it over my tires howling if you can imagine that.
steve
Old Jan 23, 2013 | 12:50 AM
Emdee's Avatar
I notice on mine that it constantly sounds like the wind is blowing at 100 mph, when I get over 60. I had the pillars fixed at the dealer I bought the truck from, but it is still really noisy. Any other suggestions? Also, how the heck do you take off the fake airbox things? ( not sure of the technical part term)
