hooking up brake controller
Old Dec 11, 2009 | 08:07 PM
twolgrl's Avatar
Default hooking up brake controller
I have to pull my tandem cargo trailer out of storage this weekend and I am going to hook up my prodigy brake controller. I know where the wires are and have the adapter, what is the best method of hook up? Should I just use heat shrink tubing?
I also checked in the fuse box and the fuse are in there. Now with my previous ford truck I had to add a relay switch, which of course was wrapped up in the glove box. Will I need one for the H3?
Old Dec 11, 2009 | 11:26 PM
08H3's Avatar
I used Scotch-Lok connectors -- easy and secure. No relays needed. Actually nothing at all needed beyond hooking in the controller.
Old Dec 12, 2009 | 01:52 PM
twolgrl's Avatar
Thanks, I am going to get some of those connectors. Hopefully the h3 wont have any problems pulling the trailer. I think empty it is close to 3000-3500 lbs.
Old Dec 30, 2009 | 06:12 PM
mcsap's Avatar
Default towing
I am very interested in knowing how your H3 tows the trailer that you describe. I have an 07 H3 and am considering getting a 3500-4000 lb travel trailer.
Old Dec 31, 2009 | 03:36 PM
twolgrl's Avatar
I was surprised how nice it handled the trailer. I use to pull it with my 07 f150 which has double the towing capacity. It was very smooth and turned well. The front end did lift a bit but nothing worth worrying about. I know that I can't load the trailer with too much weight like before (7500lbs total weight) but that just means more delivery of material.
Not sure if your 07 has the same engine or a better one but I'm sure it will handle it. When I was shopping for trailers, I actually hooked them up and went for a test drive. I would test it out at the dealer, same as test driving a car. Some trailers are built better than others and you can tell the difference when towing.
good luck
H2CANEPADESIGN
Oct 22, 2011 08:15 AM
08H3
Oct 7, 2009 04:10 PM
DNA
Aug 17, 2009 01:04 PM
USMCSKI
Apr 6, 2009 03:07 PM
Calgary
Apr 11, 2007 03:43 AM
