Holes in the hood for airflow!
Old Aug 19, 2012 | 03:59 PM
rsc's Avatar
rsc
Default Holes in the hood for airflow!
After suffering with high temps again this summer I ordered some hood louvers from www.hoodlouvers.com . Took a week to do it at work on breaks and wouldn't ya know it, when I get them in place the temps drop from over 100 to mid 80's to 90's and rain for the past couple of days! At least I can report that the vents are in a good place for air over the hood to pull air out on the hwy from the path of the rain drops up the hood. Yes, I know- only 4 rivets holding it on, did I mention it has been raining on and off? That will be fixed tomorrow. Just wish I could have had some higher temps to see how much it cools now, maybe later in the week.
Old Aug 20, 2012 | 01:01 PM
ElGuapo's Avatar
Can you post some pictures of the under side of the hood?
I like your setup.
Old Aug 20, 2012 | 04:14 PM
V8-H3's Avatar
I like the look.
Old Aug 20, 2012 | 04:42 PM
nijoma's Avatar
Default Is that made specifically for the H3?
Or is it an aftermarket company, my Alpha ran hot this summer but it was over 100 out and I was towing a lot. Interested to see if this works.
Old Aug 20, 2012 | 07:14 PM
rsc's Avatar
rsc
Temps only reached 90 again today. Why does it have to be so unseasonably cool outside?!? I haven't noticed a big difference so far, but the temps haven't been too high yet either. I feel the heat coming out of the vents when stopped, see the temp guage take (maybe?) a little longer to rise in city traffic but that could be due to being cooler outside. I can also see where the rain comes over and around the vents that there is a good negative pressure airflow in the area.
Here are the pics of the underhood and outside I took as soon as I had it tacked on for a test drive. I wish the vents were about 1/2-3/4 inch narrower to fit the cutout under the hood better- I wanted to keep all the rivets inside that area I cut out and not rivet through multiple layers of hood sheet metal.
Old Aug 20, 2012 | 07:21 PM
rsc's Avatar
rsc
it's just generic aftermarket. They have various sizes and can do custom orders too. I believe I have the 9"x14" size.
Old Aug 21, 2012 | 11:27 AM
ElGuapo's Avatar
did they come painted or did you do that?
where did you get them from?
Old Aug 21, 2012 | 01:29 PM
rsc's Avatar
rsc
They come natural, polished or painted black. I figured that I can paint and saved a couple bucks there by getting mine unpainted. Gave it a light sandblast for texture and sprayed it with Rustoleum bed liner from a spray can (almost idiot proof) for a nice texture on the top and a semi-gloss on the bottom.
The hardest part was drilling the first hole for the body saw.
Old Aug 23, 2012 | 12:26 AM
sandwich2's Avatar
Why not order the model they have for the H3 that replaces the fake plastic louver?
Old Aug 23, 2012 | 02:44 AM
rsc's Avatar
rsc
The only functional louver I have seen that replaces the plastic panel in the center of the hood weighs significantly more than the hood strut can handle by itself and I didn't want to have to screw with that detail. (or add that much more chrome) I also am not sure that I wanted a hole right over the coil packs that could allow water to leak into a known problem area. The holes I cut out are above the air filter housing and the fuse box which is fairly water resistant and easy to mount a tray over to divert water if needed.
Besides, I did it 'cuz I could and no-one else had. (and I also live in an area of the country that doesn't get a lot of rain)
