HID kit with no harness adapter?
Old Dec 12, 2009 | 11:51 AM
djcamis's Avatar
Lightbulb HID kit with no harness adapter?
So I got a HID kit for my hummer h3 with Hi/Lo and trying to figure why it has 3 adapters. So then" Oh cause it is 2 bulbs" So i go for the bulb and it has 3 wires but no apadter. Is that how it supposed to be or what? Thanks in advance.
Old Dec 12, 2009 | 01:57 PM
Tonyg41's Avatar
The h13 bulb is still under patent so technically no one can make that connector. I did get a set of low beam only hid's that did actually come with the harness I guess they broke some rules and made it for the bulbs. Usually what you have to do with that is trim the pins and you can directly connect to the car harness.You can get the old bulbs and make a harness with the old socket.
Old Dec 17, 2009 | 12:41 AM
BisePsythit's Avatar
Default HID kit with no harness adapter
I know there are vendors that sell harnesses with their hid kits for angel eyes, but I was wondering if someone could supply just the harness for an 07 build, I know its possible to hook up the 35w hid kit that I have to my angel eyes I just need the 4700uf etc. But I dont want to mess with it, does anyone know where I can purchase just the harness with the capacitor so no codes show? and I dont want to spend >50 on just a harness. Thanks
Old Dec 20, 2009 | 05:20 PM
TShepp's Avatar
I just picked up an 06 H3 yesterday and I want to add an HID kit. I know with my Dodge Magnum I had to add relays/capacitors to keep the electrical system happy in that car. Are there any CELs or issues with throwing in a a kit with this truck? Any as far as sizes I have: H13 for headlights and 9140 for fogs, correct?
Old Dec 21, 2009 | 10:41 AM
Tonyg41's Avatar
There are no error codes and such if you find a true plug and play system it's that easy. Only issue you lose day time running light you now have hid's on all the time. You can remove fuse 39 and it gets rid of the DRL's. I have hid's for my headlights and fogs I love them I have the beam aimed lower then stock to protect on coming drivers from goin blind. Still get amazing distance and brightness and no one flashing lights at me. Hope info helps
Old Dec 21, 2009 | 05:45 PM
TShepp's Avatar
Thanks for the info, Just ordered two sets of Slim HIDS. You said to pull fuse 39, Is that on the underhood fusebox or one on the interior?
Old Dec 22, 2009 | 04:57 AM
Tonyg41's Avatar
Its under the hood , you will need your manual to spot which fuse it is.
Old Feb 4, 2010 | 07:59 AM
H3beto's Avatar
Default do i need a relay harness???
what's up guys i have a 07 h3 and i got some HID and i wanted to know if i need a relay harness so they could work rite?? does anyone thanks guys
jasons38506
Sep 2, 2012 10:10 PM
tgwise
17
Feb 8, 2012 03:34 PM
simonp5150
Jan 21, 2009 09:06 AM
pteam
Sep 8, 2008 12:37 AM
CGENERAL
Apr 9, 2008 05:22 PM
