HID headlights are in...WOW
Old Dec 19, 2006 | 02:46 AM
importkiller's Avatar
Default HID headlights are in...WOW
I will never drive without them again, the difference is AMAZING!!!! You can't tell by the pics but compare the headlights to the foglights.....the fogs are the same stock bulb that was in the headlights.
Old Dec 19, 2006 | 03:45 AM
Fireman's Avatar
Default RE: HID headlights are in...WOW
How much did the bulbs set ya back?
Old Dec 19, 2006 | 04:13 AM
the bulbs,transformer and igniter was $140. Only problem I had was that the bulb was an h13 but wouldn't fit in the socket of the headlamp. I had to take a dremel and grind the plastic base of the light where it goes into the headlamp socket. 20 minute install ended up taking over 2 hours because of this, the notches matched the keyway in the headlamp housing but the outside diameter of the bulb base where the tabs are was just too damn big.... I should of sent them back but I am very impatiant
Old Dec 19, 2006 | 05:18 AM
IMPY, That looks AWESOME!!![sm=bounceybounce.gif][sm=bounceybounce.gif]
Areyou not worried about the bulbs possibly melting the factory housing??
Old Dec 19, 2006 | 11:34 AM
nah, HID'sactually run cooler from what I have read. They are only a 35 watt bulb.
Old Dec 19, 2006 | 02:46 PM
Dennis's Avatar
Awesome Bro..My hats off to you..you are such a crafty little devil with great ideas.[sm=hail.gif][sm=shades.gif]
Old Dec 19, 2006 | 03:29 PM
Thanks Dennis, I just hope when I put the HID's in the foglights that they fit a little better...I don't ever want to go through that crap again
Old Dec 19, 2006 | 03:33 PM
Cool!!! Well, They look Amazing!!!
Old Dec 19, 2006 | 03:38 PM
KTMCanuck's Avatar
Importkiller those lites look awesome. Got a couple of questions for you as I just bought a set myself. I was reading the instructions last nite and it says that you lose the autolite sensor function. Is that correct? Also does the system shutdown if you hit the highbeams given that they are no longer there?
Old Dec 19, 2006 | 03:50 PM
I did not lose the auto headlight function, I don't see how the HID kit could cause that as all the auto system is is the sensor telling the bcm to send power to the headlight...I don't think it matters what kind of headlight you have.
As far as teh high beam, yes when you hit high beam all lights shut off.
