HID + Fuse ?
Old Mar 28, 2007 | 09:04 PM
H3 Hummer 64's Avatar
Default HID + Fuse ?
Can anyone tell me when they installed their HID kit, do you have to replace the fuse for the headlights with a higher amp rated one?
Old Mar 28, 2007 | 09:31 PM
jm4490's Avatar
Default RE: HID + Fuse ?
I did with my other truck. The kit came with the fuse.
Old Mar 28, 2007 | 09:34 PM
I got my kit off my friends F-150 before she traded it in. She thinks they put in a 20 amp fuse but wasn't sure. So putting in a larger fuse won't hurt anything?
Old Mar 29, 2007 | 02:42 PM
ImportKiller can you answer this? I think you put HIDs in your rig. Did you have to replace the headlight fuses?
Old Mar 29, 2007 | 02:47 PM
importkiller's Avatar
nope, never had to replace the fuse. Only reason to have to replace the fuse is if you are going up in wattage, the HID lights use a 35 watt HID bulb where stock halogens use a 55 watt bulb.
Old Mar 29, 2007 | 03:41 PM
Ok then I'll try it without replacing the fuses. It just looks like most of these kits I've seen online come with 20 amp fuses. Can you also tell me where you mounted your ballasts?
Fahad
Dec 1, 2009 03:54 AM
MPWR99
May 3, 2009 09:42 AM
hotrod
Feb 17, 2009 06:50 PM
pteam
Sep 8, 2008 12:37 AM
philmann
Oct 22, 2006 06:49 PM
