HELP WINDOW OFF TRACK?
Old Oct 25, 2008 | 05:26 PM
RUCKUS HUMMER's Avatar
Default HELP WINDOW OFF TRACK?
I was rolling the rear passenger window up and when it got to about 2" from being all the way up it popped and then went thud as it dropped about half waydown. Itried the swicth again and nothing or no sounds going up.It will go all the way down and come back up to the half way mark and stop.I pulled it up by hand and it stayed untilI shut the door and it dropped down about 2-3" HELP!
Old Oct 26, 2008 | 08:30 AM
calif phil's Avatar
Default RE: HELP WINDOW OFF TRACK?
It sounds like the window regulator failed. They are not too hard to replace. It does suck to have to spend money on a part that you cant see.
Old Oct 26, 2008 | 09:20 PM
Itook the panel off and found some plastic parts in the bottom of the door. then I noticed a cable was loose.I pushed the window up on the bottom of the tray and used the switch at the same time andI got it to stay up.I then out a wood shim up agianst the window tray to hold it until you guys tell me what i need to do next.
Old Oct 27, 2008 | 09:29 AM
calif phil's Avatar
If the cable is loose the window regulator needs to be replaced. It's not a hard job. The aftermarket makes regulators for a lot of vehicles and they are usally about half price of factory regulators. I would check with a carquest or napa for a price and then call Hummer and see how much they are.
Old Oct 27, 2008 | 09:36 PM
Thanks for the help. I was thinking that the "regulator" was some kind of electrical or motor type part. I called the local Hummer Dealer and they said it was in stock at $318.00. i will give the aftermarket guys a call in the morning. any good online H2 parts places. Anyone know the EASY way to change it?
hummerhack
Dec 17, 2014 02:25 AM
Speedventures
Jan 14, 2008 07:19 PM
HummerGuy
49
Aug 21, 2007 07:21 PM
dougldo
Dec 8, 2006 08:07 PM
CerberusSVT
Oct 27, 2006 11:32 AM
