Help!!! Truck is stuck
Old Jun 24, 2019 | 03:20 PM
chopshopchick's Avatar
Default Help!!! Truck is stuck
No not in the mud , in the air. Back end jacked all the way up!!! Wont come down. RHE button flashing.Tried using a scanner to trick it,no dice!!! Drive over 45MPH,NOPE. Service air suspension code scrolling.Unhooked battery. UUUGH!!! codes co711 and co712. Anyone????? 06 h2 sut.
Old Jun 29, 2019 | 09:11 AM
You need a GM Tech2 or get to a dealer or shop who has one. That is the only scanner type of tool that can directly communicate with the air ride module and properly run diagnostics, do test, recalibrate the height, etc.
That being said if the compressor still works and obviously the air bags still hold air just fine, I'd closely check the grounds and other connections to the height sensors and to the compressor setup. Since it is both sides I suspect that it is not an issue with one sensor but rather a loss of a ground somewhere or possibly a connector getting corroded or something.
Old Jun 29, 2019 | 08:18 PM
Smile
Hey thanks for the response, I did infact take it to a shop where they had the scanner and for some reason it only gave a couple codes and when he tried to use the scanner to make it recalibrate it would only make the compressor click about 3 times then nothing. He was surprised it didn't work. So today we just unplugged everything that was plugged into the compressor,cycled the key a couple times,plugged it back in and started the truck with doors closed of course and boom it worked. Everything is working perfectly now.Bad connection maybe not sure but its working for now.
Mr. Demeanor
Sep 15, 2018 10:16 AM
Koobs2000
Oct 10, 2016 03:50 PM
xtremez28
Nov 14, 2014 10:20 AM
donny
Mar 18, 2012 09:15 PM
mparrish
Dec 13, 2006 07:08 PM
