Air suspension help!!
Old Nov 13, 2014 | 01:32 PM
xtremez28's Avatar
Default Air suspension help!!
I recently purchased a 2005 H2 SUT. Really enjoy the truck but having an issue and not sure what to do. I went Saturday night and bought some ceramic tile at Lowes and loaded it in the back. The air suspension started going to level the load I guess but once I got to the restaurant to eat it was still going. Shut off the truck and ate with wife and when we got out it was still going!! Drove home and unloaded the tile and it still won't shut off!! I tried all that I could and even disconnected the battery for the night and the next day when I connected the battery it went right back to going. So I pulled the fuse to disconnect the air suspension. Any ideas? What is the ramifications for disconnecting? This morning was very cold and snowing and the truck ran very rough on bumps. Is it due to cold or the air suspension being turned off? Please help.
Old Nov 13, 2014 | 04:50 PM
papsmear's Avatar
Old Nov 13, 2014 | 05:57 PM
calif phil's Avatar
One of the two rear leveling sensor arms could have popped off. I would do a close visual inspection. If that compressor keeps running it will burn up and then you might be better off with the above Arnott kit. I would try to fix it though. It's a nice setup when it works.
Old Nov 14, 2014 | 09:17 AM
Thunder Cat's Avatar
the compressor is the expensive part, air the system back up & pull the fuse to avoid burning it up, until you find the problem, I agree with Phil you have a bad sensor triggering the computer to keep the compressor on... I love the air ride set up & is one of the reasons I'm on my 2nd H2 , you may also have a badly leaking air bag & the compressor keeps pumping it with air (but the compressor should still shut off with the key)
Old Nov 14, 2014 | 10:20 AM
xtremez28's Avatar
will the rear leveling sensor arms be apparent? not sure what to look for.
PewterTank
Dec 9, 2019 01:41 PM
globalhummer
Jun 5, 2012 12:24 PM
markdoddridge
Jan 26, 2012 01:11 PM
jrem13
Apr 11, 2011 04:51 PM
calif phil
Feb 25, 2011 01:00 PM
