Help!! Rattle in 2006 SUV
Old Dec 1, 2015 | 12:43 PM
Medic65's Avatar
Default Help!! Rattle in 2006 SUV
A rattle has started in the rear cargo area. I have narrowed it down to the drivers side under the carpet/underside etc. I even rode in back with the hatch open and spare tire swing arm locked/unlocked.I checked the jack.I pulled both storage trays over wheel wells and put my hand in as far as I could,nothing.
I crawled under the rear underside and looked,touched,shook anything I could see/think of,nothing.This started a couple weeks after buying.The temps.in the area are cold,colder than when I purchased.The noise is produced by small road bumps and less. Reminds me of a loose bracket/attachment.
Here are a few things I will or have checked : Nerf/sidestep bars,Shock bushing,Shock bolts,exhaust,tire carrier,bumper and frame to underside chassis attach bolts.
Any other ideas??
Old Dec 1, 2015 | 02:46 PM
mcioci's Avatar
Any other ideas??
Get used to these rattles, esp in interior as truck gets older. The door panels will drive you nuts.
Old Dec 3, 2015 | 03:30 PM
H2Miami's Avatar
I keep tracking rattle and fixing with 3M tape . My truck has improved a lot since start doing this
Is the rattle inside ? ... while moving ? At any speed? When pass a bump ?
Old Dec 5, 2015 | 12:56 PM
flyday58's Avatar
I replaced my rear shocks and the replacements had a gap in the lower mounts between the shock bushing and the mount tangs. Shock would jiggle from side to side in the bumps making a ton of noise. Shimmed it with a thin washer and the noise stopped.
Old Dec 5, 2015 | 05:31 PM
Dieseldrums's Avatar
The rear license plate? My spare would rattle before I took it off the back.
Just turn up the radio if you can't find it.
ericles1028
Dec 26, 2012 11:40 AM
OntarioHummer
Dec 7, 2012 12:41 PM
pdxrealtor
Nov 11, 2012 03:42 PM
pdxrealtor
Nov 11, 2012 03:40 PM
Hummer2006h3
May 30, 2011 02:01 PM
