Help with Radio
Old May 23, 2011 | 09:33 AM
GBergie's Avatar
Default Help with Radio
I need some help the my H1's radio reception. Its a after market radio that for the past 6 month has a very loud screech (starting low and slowly rising high and then back low) and not all the time. some time the radio is crystal clear.
I have replaced the antenna and put a power booster on the incoming antenna line. Still have the screeching any ideas
Old May 23, 2011 | 10:30 AM
Hummer Guy's Avatar
Does the high-low noise correlate with engine revs? That can be common with aftermarket electronics of any type. It doesn't sound like reception to me - it sounds like a radio problem.
Old May 23, 2011 | 10:37 AM
Draketh's Avatar
Check your grounds, not sure how its hooked up. If you're using something like a wiring harness I would get the ground from the head unit to the wiring harness and reground the head unit to metal somewhere behind it.
Wiring harness grounds just suck.
Hummerrican
Jun 24, 2015 07:47 PM
alphadogg
37
Jul 27, 2008 08:19 AM
HERHMR
May 5, 2008 06:49 AM
crank
Jun 15, 2007 12:05 PM
Xtreme
Feb 21, 2007 08:27 PM
