Help please!
Old Nov 14, 2013 | 12:54 PM
jaxsonjj's Avatar
Default Help please!
I have a Hummer H2 all of a sudden the speedometer quit working, the fuel guage does not work either, that has been out for a while. Can these be reset somehow?
Old Nov 14, 2013 | 05:06 PM
calif phil's Avatar
You most likely have the stepper motors out and will need to send your instrument panel out for repair.
Old Nov 14, 2013 | 06:57 PM
LoJac963's Avatar
^he is correct, sounds like the stepper motors. However you don't really need to send it out. Pull out the cluster, remove the needles and gauge face (there's youtube vids on how to mark your needles and remove them), desolder the old stepper motors and solder in new ones.
The soldering is really easy just buy some good quality solder wick and a good acid core solder and you're good to go. There's videos out there on how to remove and install the motors also.
No point in spending the money to have someone do something you can easily do in your garage!
Old Nov 15, 2013 | 01:05 PM
happythree's Avatar
,,!!! never nowhere!
Old Nov 15, 2013 | 03:43 PM
LoJac963's Avatar
Whys that? I used it on every major component in the interior of my rig when I did the LED's. Cleans and etches the surface to prepare it for the solder.
Old Nov 16, 2013 | 10:25 AM
jaxsonjj's Avatar
Default stepper motor
Thanks for the info have a place in mind to send it to?
Old Nov 16, 2013 | 10:29 AM
jaxsonjj's Avatar
thanks for that, we probably can do it ourselves we will check out the videos
Old Nov 16, 2013 | 11:07 AM
Caraddict's Avatar
I see a lot of GM cars with cluster issues where I work...we send them out & have back in about a week...under $200 fix...
Old Nov 17, 2013 | 05:37 AM
happythree's Avatar
? acid flux??
acid flux is NEVER used in electrical/electronic work. you would need to give it a long hot soapy bath to ever get rid of it. it will continue to rot away the stuff it touched.
they don't even use it on copper pipe.
if you have not worked in a field like electronics you should not assume you can do just anything you think is ok.
you will notice on solder, "rosen core",rosen being the flux.
if you go to radio shack you can buy proper flux but you will not find acid there, ONLY in the hobby area where acid is used to etch away copper when making circuit boards. then you will be advised to wash the boards or the etching will continue to rot the copper away
I have made boards, I know.
Old Nov 17, 2013 | 01:46 PM
LoJac963's Avatar
Oops sorry you are correct. I have 0.022" Rosin core solder. Someone at some point gave me a roll of this huge acid core solder and that's what I was thinking about.
