Help Nerf Bar Rattle
Old Jul 8, 2007 | 04:38 PM
wrongway's Avatar
Default Help Nerf Bar Rattle
I just installed Nasta Nerf Bars on my wifes H3, I am getting an annoying rattle when I go over bumps in the road, anyone know how to fix this problem?
Old Jul 8, 2007 | 05:31 PM
blackstangs281's Avatar
Default RE: Help Nerf Bar Rattle
Only explanation is..........Something was not tightened up.
Old Jul 8, 2007 | 09:57 PM
wrongway's Avatar
You would think that, but I used an air compressor socket wrench, if anything the bolts might be over tightened, not sure if that would cause a problem.
Old Jul 8, 2007 | 10:02 PM
Did you move around or mess with the e-breake cable? That has caused some noise on some rides.
Old Jul 9, 2007 | 01:12 PM
wrongway's Avatar
I get the rattle on both sides of the truck, a friend of mine says its normal for after market bars but I am not convinced.
Old Jul 9, 2007 | 01:15 PM
Maybe they left something inside the bars. A bolt, nut, or a taboff one of the pads.
Old Jul 9, 2007 | 03:15 PM
Wendell's Avatar
ORIGINAL: wrongway
Rattles tend to radiate all over the place. So when you say you get a rattle on both sides, I assume you are inside the H3 going down the highway. Very hard to say where it is really coming from when doing this. Nerf Bars should not rattle. I would suggest you take off one side and see if the problem goes away. If not take off the other side too. I am sure you will find which side it is coming from in this fashion.
quadblaster240
Jun 24, 2012 09:35 PM
Hummer2006h3
May 30, 2011 02:01 PM
solarflare
Apr 21, 2008 08:01 PM
HingHum
Mar 27, 2007 09:00 AM
hummerman62040
Nov 11, 2006 09:26 PM
