Help lights out :(
Old May 21, 2013 | 03:55 PM
Panthers1521's Avatar
Default Help lights out :(
Hello, I have been modifying my H3 from paining the wheels and under carriage, new sound system and lighting and other little mods. The problem started when i swapped my reverse lights out for super bright LED (which are really bright and much better than stock) and when i did this my passenger brake light housing burnt out (not the bulb, the socket), I tried different bulbs that i knew worked but nothing , and now my license plate light is not working. I just bought a new socket for the license plate but that did nothing... Does anyone have any idea? Thanks guys!
-Robert
Old May 21, 2013 | 05:00 PM
Do you have a multimeter to check dc voltage & grounds at the sockets? Did you check ALL related fuses to the tail lights?
Old May 21, 2013 | 07:43 PM
That's a good idea. I will check dc voltage, I need to find the right fuse. It's not listed in the fuse box
Old May 21, 2013 | 09:57 PM
Happy Hummer's Avatar
Possibly the wiring for the tail light and tow assem. is shorting out?
Chris
Old May 22, 2013 | 07:06 AM
happythree's Avatar
backup? reverse?
backup lights are not connected to brake lites. wonder what you actually did?
a good approach is to try to go back to the original wiring b4 you messed with it.
like system restore.
these problems solutions usually lie where the last work was done b4 the shtf!
btw, the light wiring while it should be ez to understand, is not. check the diagrams..
djl1qu1d
Jan 31, 2016 11:17 AM
happythree
Jul 28, 2013 08:09 AM
bighinds
Jul 10, 2012 08:29 PM
4U2NV
Jun 15, 2010 12:34 AM
