Help identifying part
Old May 30, 2015 | 09:46 AM
  #21
Raffi76's Avatar
Originally Posted by TAINTER
81k , you need shocks.
would these do the trick?
Amazon.com: Monroe 911527 Reflex Monotube Shock Absorber: Automotive Amazon.com: Monroe 911527 Reflex Monotube Shock Absorber: Automotive
item number 911527 on amazon, I don't want to spend a lot and I read somewhere on the forum here that these are better then billsteins
Old Jun 1, 2015 | 12:12 PM
  #22
Raffi76's Avatar
Are there any specific tools required for this job? I was reading something about the bolts needing to be tightened to a specific tension ? I do not own any tools like that and was wondering if I need to buy them or is a good job tightening these by end sufficient?
Old Jun 6, 2015 | 04:43 PM
  #23
Raffi76's Avatar
Ok I replaced the shock and bump stop on passanger side today. While removing the top nut of the shock the piece that you lock in place got worked off and it would just spin. I borrowed a grinder from the neighbor and cut the whole thing off. The bump stop came out and went in fairly easily with just a screwdriver. All the bolts came lose fairly easily too but I did spray with PB Blaster yesterday. The new shock seemed a bit short but I lifted the chassis with the jack and was able to install it. My question is how far do I need to tighten the new nut on the top? I read online to tighten until the washer is just over the edge of the washer but mine is already wider then the washer from the start. I tightened until I saw it mushrooming a bit.
rsm688
Oct 15, 2014 03:40 PM
Fireguywalters
Feb 26, 2013 12:47 AM
HumV
Sep 11, 2007 07:46 PM
sjr21805
May 27, 2007 07:02 PM
crc2k
Sep 1, 2006 04:03 PM
