Help with advise please on how wide I can go on my Hulk Hummer.
Old Nov 11, 2013 | 08:57 PM
miltonluban's Avatar
Default Help with advise please on how wide I can go on my Hulk Hummer.
I purchased new fuel rims and tires for my not lifted H2 2003, about 2 months ago and the sales man said this is how fat I can go on my truck, you can see in the picture of my tire. But I would like to go fatter, I want my tires to stick out and look chubby without lifting my truck, can this be done on my rims? Or what should I do? How do I get that chubby fat tire look to stick out on my Hummer stock H2 without adding dangerous spacers?
Attached Thumbnails Help with advise please on how wide I can go on my Hulk Hummer.-zh2-tire-size-picture.jpg   Help with advise please on how wide I can go on my Hulk Hummer.-zh2-front-profile.jpg   Help with advise please on how wide I can go on my Hulk Hummer.-zh2-rear-profile.jpg   Help with advise please on how wide I can go on my Hulk Hummer.-zh2-side-full-profile.jpg
Old Nov 12, 2013 | 05:33 AM
elkgrunt's Avatar
I have 15.5 inch wide tires on mine with no problems. I also have a 6 inch lift on it.But as far as width I think it would be ok.Going taller tires you would have to put a lift on it.
Old Nov 12, 2013 | 05:47 AM
"15.5 inch wide tires on mine with no problems."
So if I have12.5, I can go real fat like you did and just keep the 35 height and I can have my fatter tires and deep lip rim I want and stay at 35 inch height and avoid the lift????
so I would have to change my rims and tires right? it's not like I can keep my rims and go fatter on the tires I guess.....
Its the lift I want to avoid, cause then I will not be able to get into my garage.
And would I have a steering problem with big fat 15.5 inches in the front? would they rub... or do I have to also change something on my front end to make it stronger for my steering?
Old Nov 12, 2013 | 08:11 AM
calif phil's Avatar
Your rig looks awesome!
Old Nov 12, 2013 | 08:25 AM
Thank You!
Old Nov 12, 2013 | 03:45 PM
LoJac963's Avatar
I'm assuming for 15.5 wide tires you'd need new rims and push the tires out so there wouldn't be rubbing issues.
Old Nov 12, 2013 | 07:37 PM
HUMVEH2's Avatar
A new set of rims is your best option for the look your going for...
Old Nov 12, 2013 | 07:55 PM
HUMVEH2 it looks like you have the rims I need and the look I want for my truck, your rims have deep lips and wide tires that stick out, your white Hummer and your wheels look great. Can you tell me the size of your wheels and tires Please, you have the look I want! And I see you don't have a lift on your truck.
Please tell me your rim and tire size cause that is what I want.....
Old Nov 12, 2013 | 09:32 PM
HUMVEH2's Avatar
Rims are 20x10 Mazzi, tires are 325/60/20 Nitto Terra Grappler.
Old Nov 12, 2013 | 09:44 PM
HUMVEH2's Avatar
Here's side view
