To heavy?
Old Aug 8, 2011 | 10:04 PM
manualman's Avatar
Question To heavy?
I won a deal on a set of pit bull tires. Their web sight says the rocker radial in 315/75/16 are 84# each. My stock 285/75/16 weigh 54#. what kind of problems is the extra weight going to do on my 2010 H3
Old Aug 8, 2011 | 10:14 PM
beitodesstrafe's Avatar
Send a PM to recovery21 (Jesse). He has pit bull tires. (He may have a different model... but I'm pretty sure all of the Pitbulls are heavy.)
Old Aug 8, 2011 | 11:36 PM
The extra weight will make you more susceptible to breaking half shafts and tie rods when wheeling.
Old Aug 8, 2011 | 11:56 PM
manualman's Avatar
Cool
I figured the usual problems. After winning the 3 gift certificates at off road-fury I looked at pit bulls web sight. Heavy. Thanks guys
Old Aug 9, 2011 | 04:47 AM
Muddydawg75's Avatar
You saw the ones Jesse had didn't you Jim?
Old Aug 9, 2011 | 06:36 AM
manualman's Avatar
Cool
They looked good but they weigh about 10# more than all the other tires I looked at
Old Aug 9, 2011 | 12:40 PM
Jim, the weight will be fine, just remember it is there when wheeling.
Old Aug 9, 2011 | 03:20 PM
That's my point.... Jesse has had 3 front diffs and he wheels as gentle as anyone I know.... he is steady and I've never seen him in anything less than a controlled situation.
Old Aug 9, 2011 | 04:26 PM
Recovery21's Avatar
WOW! You must really need a lot of tires! Did you read it closely? It is discounted when you buy a set of four.
I have the 315/75/16 Rocker Radials and yes, they are HEAVY! It doesn't take much for damage to happen with them as Stan has said. Now that my warranty is running out, I will probably end up losing them for a lighter tire. Also, do you plan on getting a matching spare? I wouldn't recommend hanging that on the back door either... I'm not sure how structurally sound the rear door is, but it is a lot of weight to be hanging on there.
You will definitely get a better deal with that Mickey Thompson one you won also. Plus their tires are cheaper and you will be saving more.
Old Aug 9, 2011 | 04:32 PM
Recovery21's Avatar
This was the latest mishap from the tires. It is not a good sound when you hear your front differential just explode into pieces. It was real bad and then all of a sudden it got quiet again. Another bad sign... I still have the spider gear as a little souvenir.
