Heater/AC fan quits
Old Jan 12, 2011 | 10:51 AM
saintsrock's Avatar
Wink Heater/AC fan quits
If the fan quits here are some places to check before you take it to a shop. Check the fuses; most likely not the problem. It will probably be the resistor pack and the harness. It is a common problem that it shorts out and melts the plug and harness. It is located under the glove box. Undo the two screws that are holding a clear plug into the fan (resisitor). A very helpful hint is TAKE OFF THE GLOVE BOX (3 SCREWS). The parts will run you $50-$70 (everything). It took me about 30 minutes but that was taking my time. I hope this helps.
Old Jan 21, 2011 | 09:43 PM
evilred26's Avatar
I had to replace this a few months ago. Unfortunately, I had to take it to a shop to get it fixed.
Old Jan 21, 2011 | 11:15 PM
Davidjones's Avatar
Hey!
thanks for your suggestion
I was nuts trying to figure out what went wrong
Thanks again for helping me out!
saintsrock
Jan 13, 2011 10:27 AM
BirdEye
Jan 12, 2011 10:06 AM
pdxrealtor
Jan 3, 2011 12:21 PM
psych0
Mar 20, 2010 10:05 AM
Trey124
Aug 18, 2008 12:16 PM
