Heat Only Blows Hot When Moving
Old Feb 5, 2018 | 06:35 AM
jy001's Avatar
Default Heat Only Blows Hot When Moving
Good Morning,
I have an 09' H3 that has developed an issue which I am hoping to resolve with some help from the experts in this forum.
The blower is working fine, however, the heater only blows hot air when the vehicle is moving. When stopped at lights or moving slow in traffic it blows stone cold air OR slightly warm air. I have also noticed that as it starts to blow hot when I start moving, the heat gauge temporarily rises looking as if it is going to overheat and then quickly falls back to normal. If there are additional details I can provide please let me know...
Any assistance, suggestions, comments will be appreciated.
Thanks,
JY
Old Feb 5, 2018 | 07:19 AM
RKSmith163's Avatar
Have you checked your coolant level?
Old Feb 5, 2018 | 07:20 AM
Happy Hummer's Avatar
Hi,
Checked your antifreeze?? Dex cool.....
Thermostat malfunctioning?
Temperature sensor?
Old Feb 6, 2018 | 06:36 AM
jy001's Avatar
Thanks for the replies... The coolant was low, I added some and problem solved.
JY
Old Feb 7, 2018 | 10:02 AM
JY
If it was that low, please ask yourself.... where did it go? Watch that level for a while, check for leaks. Check the oil and Trans fluid to make sure neither has coolant in it ASAP.
Old Feb 7, 2018 | 10:34 AM
jy001's Avatar
I checked both when I added the coolant and both were fine... Does make you wonder where it went. It doesn't smell like coolant when it's running, no unusual exhaust, etc.
Old Feb 17, 2018 | 05:32 PM
hummer_on_fumes's Avatar
I had the exact same issue in my H2 and it took an entire gallon of dexcool, so I knew something was up. Long story short, the radiator was cracked and had to be replaced. Like DocOlds mentioned, coolant leaks in the H3 (and H2) will cause catastrophic issues. I highly recommend you figure out why your coolant was so low
Mr__Mayhem
May 7, 2017 07:05 PM
ronnorw
Sep 7, 2013 06:15 PM
adilaj2002
Nov 28, 2012 12:08 PM
Tram
Dec 24, 2011 02:30 PM
racin
Aug 16, 2010 07:58 PM
