View Poll Results: Do you occassionaly get the listed problems?
yes
100.00%
no
0%
didn't really focused
0%
Voters: 2. You may not vote on this poll
headlight switch, indicator stalk problems
Old Aug 12, 2014 | 07:41 AM
a7m1's Avatar
Default headlight switch, indicator stalk problems
so, i find there is an odd problem with the headlight switch,
when it's turned all the way to the right (clockwise) off position
if you apply little pressure for some reasons the headlights lights up while holding it there
i had it happens yesterday when i had the low beam on and wanted to turn it off it went off then for a split second on while turning it to the 2nd position
it's weird
another issue, if i have to use the high beam temporarly pulling the stalk toward me and let it go , it sometimes returns too far and stays in the permanent high-beam setting which i'll discover when i turn on my headlights
Old Aug 12, 2014 | 08:15 AM
Might want to check your manual, all the way clockwise is ON, not off. Off is a quick turn counter-clockwise and released to spring back to the straight up center auto position. The 06s function just a bit different than the rest.
Old Aug 12, 2014 | 08:26 AM
a7m1's Avatar
no !!!
sorry for the confusion
mine is 2009 from middle east ( kuwait)
clockwise is off i am 100% sure
if u apply just little pressure while it's off to the off position the lights go on not really sure which lights exactly
wait i am not really sure what car that you're talking about probably our switch is different
this is the switch i am talking about
if i got the light to the off ( far right) and apply little pressure lights start working if i release the pressure it goes off
i don't want this thing to fail on me and drain my battery
Old Aug 12, 2014 | 08:28 AM
a7m1's Avatar
i know what are you talking about , but in my 2009 h3 it's not the same
on my car i have the option to leave it completly off every single light as opposed to auto spring loaded tension
on 2005 trailblazer it's like what are you indicating
Old Aug 12, 2014 | 08:47 AM
You did not indicate which year and model you have, now we can see the light as to why that is important. (Pun intended )
Old Aug 12, 2014 | 09:06 AM
a7m1's Avatar
ye i am really sorry about that never thought there is any changes, BTW i really appreciate your help <3
when i talked about the opposite rotation i thought it's region differences
hopes this clear things up,
so is this switch failing or it's normal operation?
it's smooth and clicks fairly easy on every mode i must say
what about the indicator stalk that sometimes pops into permanent high-beam when i use the temp high-beam is this faulty?
EastTnMike
Jan 3, 2015 06:30 AM
dyydjbb
Sep 6, 2014 08:54 PM
wfturner
Mar 20, 2012 06:09 AM
joewcob3
Dec 21, 2008 03:11 AM
