Head LIGHT issue
Old Nov 24, 2007 | 10:46 AM
pmalla5's Avatar
Default Head LIGHT issue
OK last night i was going to pullout and i had to turn off my head lights for a sec, but when i i turned tem on one did not go back on so i went and checked te bulb, its fine.
i turn on the highbeam they both turn on, when i turn off the high beam only one is on. so i looked around the circuit box, and when ever i turn on or off the lights the low beam fuse clicks. i have no idea wat to do becasue only one head lights works, im not sure if the fuse is bad or what??? PLEASE give me insight.
Old Nov 24, 2007 | 11:07 AM
alrock's Avatar
Default RE: Head LIGHT issue
ok, how do you know one bulb is fine? Low beam and high beam uses different filaments. Low beam can be burnt out and/or broken while high beam works. Sounds like the bulb needs to be replaced. [/align]
Old Nov 24, 2007 | 12:04 PM
pmalla5's Avatar
no i replaced the bulb same problem. that was the first thing i thought of
xroperx
Head and Valve Problems.
170
Apr 13, 2009 07:46 PM
SeaGar
32
Dec 28, 2007 02:47 PM
btstyx
97
Aug 2, 2007 09:34 PM
Linus Gump
Jun 21, 2007 12:53 PM
altrestle
Mar 23, 2007 04:30 PM
