Has anyone installed a oil gauge in thier rig?
Old Apr 7, 2018 | 02:00 PM
Dave73's Avatar
Default Has anyone installed a oil gauge in thier rig?
Was wonderung if anyone installed a oil guage in thier h3? If so, was it electric or mechanical? How did you run it? Would appreciate hearing about it...thanks dave
Old Apr 7, 2018 | 03:53 PM
happythree's Avatar
yrs ago i used a "t" so i had both on fords. on h3 i searched and found nothing that matched the sender threads. i think someone did, but dont know where?
i want a stewart warner if i can.
Old Apr 7, 2018 | 07:51 PM
woodwardsh3's Avatar
ebay has one that threads in to the oil sender hole and is threaded in the side and the top.I ordered one but have not used it yet. I will see if i can find what I ordered.
Old Apr 7, 2018 | 07:54 PM
Here is what I ordered back in 2016
item sold by tsto1303
Oil Pressure Sender Tee Adapter LS1, LS2, LSx
( 172221470744 )
Old Apr 8, 2018 | 01:28 PM
blazed16's Avatar
I have a couple oil gauges from my old suv i never actually got to install 1 be nice if i could use in H3
Old Apr 8, 2018 | 02:29 PM
Chimpy's Avatar
Maybe go with a Scangauge?
Old Apr 9, 2018 | 12:38 AM
jens's Avatar
Good morning from germany.
I'm on my way to install an oil pressure gauge on my 2006 H3, because i had the idiot light on when the truck was in idle. It was only a plugged oil pickup screen, but you all know how bad it is, to get the oil pan dropped....
Now i want to see my oil pressure all time, to be able to react before the oil light comes on.
There is a good tutorial on "355nation" i used to find the location and the fittings to get the pressure pickup installed.
https://www.355nation.net/forum/i4-i...ure-gauge.html
The thread above the oil filter, where the plug is removed, is metric M16 x 1,5.
As far as i know, does the pcm not provide data of the motor oil pressure...
Have a nice day...
Jens
Last edited by jens; Apr 10, 2018 at 01:38 AM. Reason: Wrong thread size!!! It's M16 x 1,5!!!
Old Apr 9, 2018 | 11:56 AM
happythree's Avatar
i guess it would need a pressure sender?? none there huh..
let us know how you do it..
Old Apr 25, 2018 | 02:44 PM
jens's Avatar
Hey,
i finished installing an oil pressure gauge on my H3.
I had to clean the oil pickup screen, because it was clogged with pieces of carbon and i had the oil pressure alarm.
I used the discription, i wrote of in my previous post...
Here is a picture of the oil pressure sensor in place...
I placed the gauge on the left corner of the dashboard...
I even checked and cleaned up my valvecover...
You can see the missing sealant on the baffles. The H3 smoked a little bit blue, 20 seconds after startup
i removed the baffles and cleaned everything up?..
... and sealed everything with new rtv...
Tomorrow i have to reassamble the whole thing and check everything up...
kramcard6
34
Feb 25, 2013 02:56 PM
8lug
Jan 27, 2013 12:59 PM
Intercooled
Jun 26, 2008 12:07 PM
Coug_H2
Apr 15, 2007 07:09 PM
whth3
Jan 11, 2007 08:53 AM
