H3 vibration
Old Apr 25, 2012 | 10:56 AM
rich1de2's Avatar
Angry H3 vibration
We have a 2008 H3 with 50,672 miles, when it shifts into 3rd gear and traveling along it starts to vibrate like ur running over rumble strips on the road. It just started doing this. We have a dealer appointment this Friday but I was just wanted to know if anyone had a similar problem.
Old Nov 8, 2012 | 02:50 PM
KJTCMSGT's Avatar
Default 2008 H3 with slight vibration at 45-55 mph
I have had a simliar problem;however I have not had my H3 very long. So I started with a fuel cleaner, didn't work. So I took to have a front end alignment, tires balanced and rotated, and my tires were shaved to be rounded. I also had the brakes replaced. I still have the slight vibration. I also had the air filter changed. Still the same problem. I just used another round of fuel injector cleaner with my last fill up. I am also going to clean the throttle body and MAF next. My H3 only has 53K miles.
Old Nov 8, 2012 | 07:15 PM
Hunner's Avatar
Just one opinion. If you don't think it is the engine maybe you should check the drive shaft ujoint and front CV for slack.
Old Nov 9, 2012 | 05:46 AM
Pappibri's Avatar
I was going to say as well that it might be the Ujoint. Anytime I have ever experienced that in which you are speaking of, it usually turned out to be the Ujoint.
Old Nov 9, 2012 | 06:53 AM
BERULAKIDE's Avatar
Ok, kinda in the same category. I have a whining noise in the front passenger side,and it is worse and sounds like a rubbing or something at really slow speeds and not as easy to hear once ul to speed. It popped once when backing up and turning.
I was wonderring if it would be the cv or axle assembly. I did the brakes not long ago and am positive it is not that.
Old Nov 10, 2012 | 04:46 PM
rich1de2's Avatar
Smile update...
it turns out there was problems in the transmission... several trips to the dealer they rebuilt it...
Old Nov 10, 2012 | 10:40 PM
Hunner's Avatar
Was it the torque converter shuddering or did they say?
Old Nov 11, 2012 | 04:52 AM
rich1de2's Avatar
Question update
the first time they replaced the torque converter... drove it home... same problem... the second time they replaced the t.c., radiator, and rebuild the trans... they said the radiator went bad and got antifreeze in the trans. fluid...
Old Nov 11, 2012 | 11:25 AM
Hunner's Avatar
Oh! I have heard of that happening, not good.
I think some people installed a remote tranny cooler and by passed the one in the radiator.
Glad they got you going.
Ghostrider
18
Aug 28, 2007 08:31 AM
tteazis
May 6, 2007 10:13 AM
rexscott
Feb 9, 2007 11:19 AM
crank
16
Aug 2, 2006 04:06 PM
G Man
Feb 25, 2006 05:58 PM
