H3 SUB SET UP HELP GUIDE
I MADE THIS TO HELP EVERYONE AND GIVE SOME IDEAS TO MAKE YOUR H3 HAVE A GREAT SOUND SYSTEM. AND YOU DONT NEED TO SPEND 100'S OF BUCKS ON CRAZY **** IF YOU HAVE A FEW HOURS A WEEKEND(PUT DOWN THE XBOX360)PICK UP A SCEWDRIVER AND GET TO WORK....BY THE END I JUST MIGHT HAVE MADE YOU LOSE 200 CALS...THATS ABOUT 1 1/4 CAN OF SODA....THINK ABOUT THAT.
http://i45.photobucket.com/albums/f8..._2-ohm_2ch.jpg
http://i45.photobucket.com/albums/f8..._4-ohm_2ch.jpg
http://i45.photobucket.com/albums/f8..._8-ohm_2ch.jpg
OKAY THE FIRST 5 CLICK ARE SUB/AMP SET UP...BY OHM AND ON A 2 CHAN AMP....
http://i45.photobucket.com/albums/f8...KDOORSOUND.jpg
http://i45.photobucket.com/albums/f8...DOORSOUND2.jpg
http://i45.photobucket.com/albums/f8...DOORSOUND3.jpg
THIS IS THE BEST PLACE AND ONLY PLACE TO PUT 2 8" SUBS WITHOUT LOSING SPACE IN THE TRUNK! THE HARD PART IS WHERE TO PUT THE AMP SO ITS HIDDEN! ITS NOT LIKE THEY GAVE US A SECURITY COVER FOR THE CARGO SPACE.
"Another issue you can run into with factory head units is the lack of RCA outputs. For this you will need either an adapter to convert the speaker output signal to an RCA signal or an amplifier with a built in adapter. These are often referred to as high level to low level adapters or speaker level to RCA adapters. They run $10-30 and are available at car audio shops and related businesses. For premium systems such as Bose, JBL, Infinity, etc. you will likely need a specialized adapter. Companies such as PAC, Peripheral Electronics, Soundgate, and Precision Interface Electronics all make these type of interfaces. For even more advanced factory systems that also require re-equalization look to Alpine (Imprint), AudioControl (DQL-8), JL Audio (CleanSweep) and Rockford Fosgate (3Sixty). "
http://i45.photobucket.com/albums/f8...UMMER/sven.jpg
NOW THIS IS THE SVEN4($56.95 BUT I GOT IT FOR $30) YOU WILL ALSO NEED SVHGMAA1($20)
Charlie
Jun 29, 2012 05:39 AM
myrddin
Aug 9, 2010 05:24 PM
hearseman
Aug 5, 2010 09:26 PM
