H3 side mirror problems
Old Jul 6, 2013 | 02:22 PM
hoghummer1's Avatar
Cool H3 side mirror problems
Hey guys. I have an 07 H3. Awhile back both my side mirrors quit working all the sudden. They are just power mirrors. Coincidence, the sunroof controls have quit working as well. By pressing the sunroof button I can open and close it however the automatic one touch button for the sunroof doesn't work....I have to hold the button down to open or close it. I have checked all the fuses and cant find anything wrong with them. Any help would be greatly appreciated
Old Jul 6, 2013 | 04:35 PM
Start by checking / replacing fuses:
#9-15A(sunroof module,turn signal/multifunction switch, AT floor shift control)
#56-30A(mirrors, Front turn/hazzard/courtesy:BCM)
______________________________________________
#57-15A(sunroof motor) Good.
Under hood fuse block, make sure you have the right fuse as fuses are color coded to amps.. GL
Old Jul 6, 2013 | 09:58 PM
happythree's Avatar
did you look at the wiring diagram to see if the notorious driver door switch module is involved?
check connectors.
try the old reset trick,unhook the batt,touch terminals together,pray,,,
Old Aug 27, 2015 | 08:58 PM
cliffster's Avatar
Here's the simple fix for hummer mirrors that quit. lift out the switch module with all the switches on driver door. It juust picks up and out.skin back the orange wire feeding the mirrors..See if you have battery voltage. If not its failed in the bc module. NO BIG DEAL. The other orange wire three inches away feeds the door locks. I ran a jumper from the door lock orange to feed dc to the mirrors. works perfectly. For safetys I soldered in a 3 amp spade fuse on the jumper. works perfectly. 10 minutes.The hot circuit failed in the body control module. if you have hazards and courteysy lights it's not the fuse. it wont damage or back feed cause its open in the bcm.
Old Aug 28, 2015 | 08:13 AM
Thanks for the assistance in this 3 year OLD thread.
Old Aug 29, 2015 | 12:00 AM
H3Ray's Avatar
I had this problem and suffice to say I purchased a whole new sire mirror ... set me back $350 bones!
Old Aug 29, 2015 | 09:59 PM
happythree's Avatar
i think i paid a yard $125.
always shop yards first.
Old Aug 30, 2015 | 05:05 AM
H3Ray's Avatar
I meant to say "side".
wpage
Jan 20, 2016 08:04 AM
bosch
Jul 14, 2010 01:01 PM
tzhmmr
Jan 13, 2009 08:22 AM
hummer1
May 18, 2007 10:37 PM
hummana
Jan 21, 2007 09:48 PM
