h3 oem radios
Old May 16, 2011 | 08:32 PM
ironbike1@q.com's Avatar
Default h3 oem radios
i have an h3 2007 with a oem radio in it, i purchased another
2007 h3 oem radio with the upgrade indash 6 cd am/fm xm option
i want to put it in mine but i can't get an answer from 3 dealers
may not be asking the right questions. i just want know if its going to
work. gm part #15786124
Old May 16, 2011 | 09:31 PM
2wheelmonster's Avatar
doesn't your h3 2007 already have the indash 6 cd am/fm xm option already in it, I believe that it does already, and if you check the part numbers for the same years and the same model, my guess is that you will find that for your 2007 h3 that it will work in your h3 2007....
Old May 16, 2011 | 09:48 PM
drtom's Avatar
Banned
radios are theft protected. need to be reprogrammed for the new vin no.,,assuming its not on the stolen list!!
if both radios look alike,,they are!
Old May 16, 2011 | 11:21 PM
Default more oem questions
my 2007 hummer h3 came with the single cd am/fm
no xm thats why i wanted to put the upgrade 6 cd player
am/fm xm capability, that why i wanted to change it out
(the dealer)
Old May 17, 2011 | 10:21 AM
Bunger's Avatar
(the dealer)
Are you sure that it doesn't have XM?
I have a 2007 H3 Base model. My radio is a single CD AM/FM/XM
Have you scrolled thru the BAND button? Mine goes FM - FM - AM - XM1 - XM2.
Old May 17, 2011 | 12:11 PM
jvorpahl's Avatar
I am 95% sure that I don't think it'll work b/c the base radio has an internal amp that drives the speakers. The 6 disc is designed to work w/the monsoon so it only has a preamp. The external amp drives the speakers. Also the radio harnesses are 100% different between the single disc and 6 disc so you have a huge issue w/that. Best bet is to keep the single disc and buy and XM radio controller. I know it sucks b/c it isn't integrated into you stereo but that is the easiest. If you have extra money buy a double din Cd/DVD unit that is satellite ready (will cost about $400 and up) and purchase the xm satellite add on (usually runs about $80 for most brands).
Also I don't think the XM reciever is in the radio itself. According to the wiring diagrams it's on the right hand dash side. It's called the digital radio reciever. The radio is just XM ready and you need the digital radio reciever to get XM. I've never looked at mine in person so I can't say for sure but it looks like a seperate unit on the wiring diagrams. Can someone confirm this?
EDIT: You can also get a XM ready single din cd player for a lot cheaper than a double din but IMHO it won't look as good.
- Jason
Old May 17, 2011 | 12:36 PM
Broken Halo's Avatar
- Jason
Confirmed......the harness going from the separate unit to the radio are the wires you can splice into to hook up an input jack for a MP3 player. There was a recent thread on the subject.
Old May 17, 2011 | 09:07 PM
thanks for the input guys, i'll try your other suggestions
Old May 18, 2011 | 11:46 AM
- Jason
Good stuff guys, right on. I researched all this years ago and this is about as far as I got. All you need to know on the subject.
Old May 18, 2011 | 09:55 PM
Bullwheel's Avatar
Ok...something to think about:
I have a 2007H3 and mine came with a single CD player and Monsoon speaker system!
Just a recommendation:
If you change, then to aftermarket systems what usually are of better performance.
Why play around with 6CD changer? ...buy an I-pod and use this one...!
