H3 OEM Nav to CD Changer Swap
Old Jan 22, 2018 | 11:17 AM
indeedido's Avatar
Default H3 OEM Nav to CD Changer Swap
I've got an '08 Alpha with Monsoon factory navigation. I don't use the nav and would rather have the 6 disc OEM changer. The harness pins look the same on a 6 disc and the nav, should be a straight swap right? I don't see anything that would make me believe there is a "Monsoon 6 disc" headunit and a "regular 6 disc" headunit. Not like there is a sub out level control. Correct on both accounts?
Old Jan 22, 2018 | 03:44 PM
happythree's Avatar
i think monsoon is the only 6 disc. do you have sub/amp?
Old Jan 22, 2018 | 03:54 PM
indeedido's Avatar
I do, I've got the monsoon now with the nav head unit. Looks to be plug and play, and dealer reset of course.
Old Jan 22, 2018 | 06:02 PM
BruceS's Avatar
Nav came with monsoon also. I had 6 cd then changed to nav. If you stay OEM the only thing you must do is install unit and then go to dealer to have vin programmed in. If you chose to swap back no issues as the original unit already has your vin programmed. When I had it done dealer charged $40
Old Jan 23, 2018 | 12:19 PM
happythree's Avatar
i have a spare 6cd radio. are you saying i can have both set up to use?
id like to have a working backup.
love my monsoon!
Old Jan 23, 2018 | 06:07 PM
BruceS's Avatar
The original is already programmed with vin. Get the other one installed and then programmed. If something happens you can pull it and put the original one back in. Plug n play. No reprogramming needed.
Old Jan 23, 2018 | 10:37 PM
happythree's Avatar
ok thanks. i thought maybe the radio info was put into the h3 comp,the reverse.
i have a friend working at gm dealer. ill see if he can get me fixed!
SundownAudioNY
Sep 6, 2011 03:02 PM
Size-Matters
Jan 1, 2011 11:30 PM
dinov
Jan 1, 2011 02:07 PM
dinov
Feb 28, 2010 11:25 AM
Mobiledave
Jul 24, 2009 04:38 PM
