H3 Makes Screeching Sound On Sharp Turns
Old Aug 30, 2010 | 06:42 PM
H3_2009's Avatar
Default H3 Makes Screeching Sound On Sharp Turns
I have a 2009 H3 and I am noticing that it makes a screeching sound on sharp turns. Is this a power steering problem? Has anyone else experienced this on their H3?
Thanks in advanced for any comments!
Old Aug 30, 2010 | 06:51 PM
Slash x's Avatar
Cool
Don't know what to tell you since you have given little information other than hard turning that causes this sound.
A lot of vehicles when locked (left or right turn) exibit this sound from the motors fan belt slipping on the pulleys because of the "Locked" wheel. I would possibly start with inspecting the fan belt and see if it is loose or cracked. Loose serpintine belts may cause a slipping and squeeling sound when steering is locked.
With out more info, that's my best guess for now
Old Aug 30, 2010 | 07:49 PM
Mr. Fancy Pants's Avatar
use sure it's not the tires?
Old Aug 30, 2010 | 08:32 PM
85_305's Avatar
Banned
it could def be the tires because of the way the front diff is setup
Old Aug 30, 2010 | 10:24 PM
H3_2009's Avatar
Would tires make such a noise? And how could one determine it is the tires? Thanks for your insights.
Old Aug 31, 2010 | 02:22 AM
Tonyg41's Avatar
Yeah its definitely your tires, I have a 2009 h3 and when you make sharp turns its how the tire is touching the road and the weight shift. I kinda like it cause it sounds just like what you hear in the movies when they have the car chases plus I make my presents known when I turn at a traffic lights. To make sure it is your tires turn your wheel all the way and do a circle at very slow speed like crawling.If you dont hear it and as you speed up you hear it thats how you know for sure its the tires. If it squeaks at like 3-5 mph your hearing something different then me and maybe need to get it checked out by dealer.
Old Aug 31, 2010 | 06:09 AM
or you could try turning on something other than asphalt like dirt or stone to see if it only makes the noise on asphalt.
Old Sep 1, 2010 | 05:19 PM
WarMongur's Avatar
Mine does the same thing ... its the tires on mine. Unless it sounds fluid/hydraulic ... then maybe ur power steering has an issue.
force0009
Feb 2, 2013 03:59 PM
dilo2001gt
Apr 3, 2007 03:52 PM
dilo2001gt
Nov 6, 2006 06:41 PM
HummerGuy
30
Sep 2, 2006 06:08 AM
dilo2001gt
Aug 2, 2006 07:21 PM
