h3 level kits. Who maskes the best one
Old Jan 6, 2008 | 07:53 PM
H3_seabee's Avatar
Default h3 level kits. Who maskes the best one
H3level kits.
I am looken to level my2006 h3 out and would like to know who makes the best one out there? Second question what are the best tires I can get to make my H3 look a littlebetter after I level out . I am looken to add a little more meat on them and keep my stock wheels.
thanks,
Chris
Old Jan 6, 2008 | 07:57 PM
importkiller's Avatar
Default RE: h3 level kits. Who maskes the best one
All leveling kits are a complete waste of money...just turn the t-bar bolts to level the truck and buy a goodset of new longer shocks...all the leveling kits do is give you reindexed t-bar keys which only change the starting location.....by turning the stock t-bar keys you can level the truck off and not notice ANY change in ride because you are not changing the spring rate.
Old Jan 6, 2008 | 08:13 PM
rhill20's Avatar
https://www.hummerforums.com/searchp...bmitbutton=+OK+
They're are ALOT of threads there about leveling your H3. I personally did the Torsion Bar crank then got an alignment done. Cheaper, faster, and easier. You will get different opinions on this from everyone. Go with what you want, but like Impy said; They TB crank works just fine. I did it about 4,000 miles ago and everything is fine.
Old Jan 6, 2008 | 08:45 PM
GM.......It's already on your truck. The T bar adjusting bolt is 1 1/16", just tighten to level Left to Right, and up from there if you need to. Links.
The forum has a SEARCH feature. Check it out sometime, it actually works.
Search and you shall find.One of the best Front Leveling/Shocks & 35" Tire/Wheel FAQ; RE: How much can I lift the H3 without...;
RE: Asking advice on H3 leveling kit (Please); RE: Leveling kit VS. Torsion bar adjustment; Leveling Kits - Can Anyone Explain Their Value?;
RE: Readylift or Truxxx Lift Leveling Kit? Ready to buy
; RE: Front End Lift Followup; RE: Shocks
Good stuff
Old Jan 6, 2008 | 08:47 PM
doc is the search king...LMAO
Old Jan 6, 2008 | 08:49 PM
Saved to favorites for the repeat questioning newbs. It's all gonna look the same for a while [&o]
Old Jan 6, 2008 | 10:19 PM
alrock's Avatar
The FAQ is the best thread by far, IMO. It helped me cement how I'm going to level my H3. Cognitos, crank the torsion bars, alignment. I think that's pretty much it. [/align]
Old Jan 7, 2008 | 05:23 AM
hilljob26's Avatar
shock extenders give you the full level,with your t-bar crank
Old Jan 7, 2008 | 03:49 PM
VanSmite's Avatar
I plan on doing the Tbar crank with new (longer) cognito shocks. Never heard of a bad crank. I'monly doing two turns. Also, if you ask me, some of those kits look like they lift it a bit too high in the front.
As for tires, I think most agree that the Toyos & MTZ's are the best way to go as far as looks and performance. I also hear good things about BF Goodrich Mud Terrain, but these and the Toyo's may be a bit louder on the road than the MTZ's.
What size tires are you looking for? You can clear 35's with slight rub even without a tbar crank. Understand that the stock wheels for a H3 are narrow however, so if you go 34" or 35" it will rub unless you use spacers.
** I may still be a newbie, but I graduated from the Doc+ Import + Search = H3 institute of higher learning!**
Old Jan 7, 2008 | 04:06 PM
your diploma is in the mailThe narrow rim is not why it may rub at full lock with stock wheels though...it rubs because of the wider tire and the fact that the offest of the rim is so drastic.
kshummer
Hummer H3T
29
Aug 18, 2011 12:04 PM
theviper90210
Dec 28, 2010 08:54 PM
FloridaFeMan
Feb 8, 2010 10:51 AM
dilo2001gt
Jul 18, 2007 06:50 PM
