H3 How to lower front???
Old Nov 13, 2010 | 08:01 PM
maoelchurro's Avatar
Default H3 How to lower front???
Hey, many of u guys adjust the torsion bar to lift the H3 but is anyway possible to lower the front on an H3?? please let me know.
P.S: why I wanna lower it? I will tell u later, thanks
Old Nov 14, 2010 | 01:32 AM
drtom's Avatar
Banned
u turn the bolts,,the other way
Old Nov 14, 2010 | 07:21 AM
Broken Halo's Avatar
I don't know that I would jump into doing that! The torsion springs give you a solid ride by having a 'pre-load' to them. Remove the pre-load, and you've got yourself a metal rod, not a loaded spring. You would turn your ride into MUSH!
Old Nov 14, 2010 | 07:39 AM
drtom's Avatar
Banned
the factory sets the ride height to an engineered specification that fits the design of that vehicle.
in the service manual there is a precise measurement/adjustment to set the vehicle according to spec. it in the center of the suspension travel range,approx.its that way when delivered.
any deviation up or down takes the vehicle out of spec. most owners,for some reason raise their h3 within that range.
if they went to the top there would be no further upward travel left, and same as such going down.
in the center,+- there is always a load on the bars, even when set out of factory spec.
i would guess you could lower it as much as some raise it, or go to the ground!!
Old Nov 14, 2010 | 07:47 AM
You are correct.....MY concern is, if he gets carried away trying to lower it too much, he will go outside of the springs 'working range' limits.
Old Nov 14, 2010 | 09:23 AM
drtom's Avatar
Banned
i think you'll find the working range is the weight of the veh set at factory spec. the wt, dont change as it is adjusted up/dn so tension should be same.
the bars are installed as a bar of metal,no tension when the frame is lifted so the wheels hang down held by shocks. the bars are plugged in and the weight loads them. the adjustment sets the factory ride height, same weight
Old Nov 14, 2010 | 12:22 PM
well.... this is what i did.
I lowered it my car with ground force kit just the rear 2".. but it was too much. So thanks to ur advice I lowered the front just about 1 cranked to the other side. so the meausures are.
Rear: from the wheel to the fender 25 1/2
front: from the wheel to the fender 24 1/2
I Will post pics tomorrow.
Old Nov 14, 2010 | 01:36 PM
drtom's Avatar
Banned
ill beee lookin!
hey its time somebody slams one!
Old Nov 14, 2010 | 02:08 PM
well... i live in Miami dont need to lift my car
plus i dont like those big gaps.... with all u guys respect.
Tks
Old Nov 15, 2010 | 12:40 PM
