H3 emergency brake install - how to ?
Old Dec 16, 2015 | 04:12 PM
DGV505's Avatar
Unhappy H3 emergency brake install - how to ?
Had to replace pads in 06, H3, E-Brake shoe came loose while removing the brake drum.
QUESTION) How to put the E-Brake back on ?
There must be a technique in putting it back together with the 2 spring & button on the sides and also the top and bottom springs with the adjuster.
Spent a good amount of time on this...I would pull my hair out ..but I am bald already !
Attaching pictures.
Pic 1 shows after the shoes have dislodged.
Pic 2 - most important--shows the shoes and springs laid out on the floor .. as would be seen looking directly into the wheel. The other pics are general.
Any help would be immense !!
Attached Thumbnails H3 emergency brake install - how to ?-pic-1r.jpg   H3 emergency brake install - how to ?-pic-2r.jpg   H3 emergency brake install - how to ?-pic-3r.jpg   H3 emergency brake install - how to ?-pic-4r.jpg   H3 emergency brake install - how to ?-pic-5r.jpg
Old Dec 16, 2015 | 05:48 PM
Paranormal's Avatar
Give You Tube a search. Lots of good info there.
Old Dec 16, 2015 | 06:36 PM
DGV505's Avatar
Thanks...did look around You Tube first...but all are completely different than the H3.
Old Dec 17, 2015 | 08:34 AM
Go around to the other side, the one you did not mess with yet, and LOOK at how it goes together. Service manuals are on line free.
Old Dec 17, 2015 | 02:13 PM
DGV505's Avatar
Thanks Doc Olds, not sure if the last reply is going to show up; yes I have seen this drawing on the web and seems obviously easy & similar to the setup on other side as suggested. However the problem is what goes where first...more like a procedure, maybe the technical service bulletins would help. (I will also loosen up part "9" on the drawing above)
Meantime do you know the service bulletin site ?
Old Dec 17, 2015 | 07:00 PM
Paranormal's Avatar
Scroll down the attached link. I believe you'll find what you are looking for.
http://schwarttzy.com/wp-content/upl...king-Brake.pdf
K0PIR
Feb 25, 2012 08:09 AM
hummerkauai
Oct 26, 2011 12:05 PM
eflower
Dec 11, 2010 07:58 PM
HummerGuy
Apr 30, 2008 10:51 PM
ultimatesecurity
17
Jun 14, 2007 02:18 AM
