H3 cruise control
Old Jun 3, 2015 | 05:04 AM
Bad hummer's Avatar
Default H3 cruise control
Hi guys, had a recent fault and found my brake light switch was stuck in, I pulled it apart and relubed it. Works great again now but my cruise isn't working, could the switch be slightly out of position? Or is there a fault code that needs to be reset before the cruise will work again?
Any help greatly appreciated
Old Jun 3, 2015 | 09:00 AM
The code may trigger the cruise to be inoperable.
Have the code erased and report back with your findings.
Old Jun 3, 2015 | 10:32 AM
X2 if the PCM thinks the brake is depressed, ie. stored code.
Old Jun 4, 2015 | 12:24 AM
H3Ray's Avatar
This is NOT entirely accurate because if the computer says the brake is pressed the code is there and will appear. Come one Tinter...
Old Jun 4, 2015 | 10:13 AM
Wow HERPES, there seems to be a lot you might want to learn about modern vehicle technology before posting such rubbish.
Once an issue is fixed like the above issue. The idiot light will not be lit anymore but in most modern vehicles the body computer and engine computer "store codes" to be accessed later by a technician at a later date through the OBDII port. In this case the BCM may have stored a code or codes that do not show up with the blinking idiot light on instrument cluster thus the inoperable cruise control.
We are still waiting to see if this is the case from the OP.
Old Jun 4, 2015 | 11:39 PM
H3Ray's Avatar
I gave my opinion and you gave yours so why get your panties in a knot?
Old Jun 7, 2015 | 05:15 AM
Bad hummer's Avatar
Ok after 2 combustion cycle the ecu has let the cruise function again
Old Jun 8, 2015 | 06:03 AM
Great! Looks like after a few cycles the stored code cleared.
mrvictory1999
Nov 21, 2020 12:14 PM
Johnny B. Epic
Mar 31, 2012 07:56 PM
gerry
Jan 6, 2010 03:13 AM
tavion2378
Jun 8, 2009 03:01 AM
Inspignant
Mar 26, 2009 06:45 PM
