h3 cracked bell housing
Old Apr 12, 2012 | 11:11 AM
RickStang's Avatar
Default h3 cracked bell housing
so after taking in my 06 h3 to get my rear main seal replaced (I was told by my dealer it was the rear main) I got a call from the shop asking me to come in and check out a big problem. The bell housing is cracked about 4 inches in length. Replacement cost assuming there is no damage behind the housing is $1600. I talked to a bunch of different mechanics from different shops and they all said that only 2 things can cause this, poor heat issues, or something breaking off inside the engine and causing it to crack the housing from the inside out.
So I love the h3 and rather than paying for the housing and any additional parts assuming it was cracked from the inside out I started thinking of getting a new motor. 1 shop says motor+ all labor $7400. Still waiting for estimates from other shops.
The reason I cant trade it in is because on Jan 1st I was hit by a drunk driver head on and caused 10 grand in damage so I wont get squat from dealer.
Anybody have experience with any of this
Old Apr 12, 2012 | 12:26 PM
drtom's Avatar
Banned
bell housing is front of tranny,right?. chunk of metal $1600?
it bolts to the engine, not part of it huh
looks like aluminum, about 10 lb. 160/lb!
then again,if it was running till they found it,just how much of a problem is it?,maybe none.
lets see the pictures u took.
Old Apr 12, 2012 | 12:40 PM
SedonaBoundH3's Avatar
How many miles on the truck? With an engine swap, you pay a lot of labor for swapping engines externals. That $5800 difference vs replacing the bell housing would pay for a lot of rebuild and mods. Warrantied remanufactured 3.5s seem to go for around $2500.
Old Apr 12, 2012 | 12:58 PM
Scouser's Avatar
Maybe the head on collision caused the crack and so claimable against the drunk driver.
Old Apr 12, 2012 | 01:03 PM
HUMMERUP's Avatar
I'm with this guy!
Make a phone call to HIS insurance co. ASAP
Old Apr 12, 2012 | 01:36 PM
Originally Posted by HUMMERUP
I'm with this guy!
I'm not sure about Auto Insurance in Alberta Canada, but in Michigan (a No-Fault Insurance state) your own insurance pays for damage to your own vehicle. The only thing you can get from the other driver's insurance company is your deductible up to a maximum of $500.00, and only if the other driver was at fault.
Rick: When you asked all these shops how a bell housing can crack, did you fail to mention the head on 10K damage collision? I'd bet your collision repair facility missed that one.
If the motor moves from a collision because of damage to the frame or motor mounts, you can get a busted bell housing.
Old Apr 12, 2012 | 03:18 PM
HUMMERUP's Avatar
Ya I'm not sure about Canada either. Here in Washington the driver at fault's insurance company pays for all settlements.
Old Apr 12, 2012 | 08:09 PM
RickStang's Avatar
In my deductible was covered (1500). I will give my insurance company a phone call tomorrow to see what can be done. The motor itself is $4000 with $300 returned if my engine gets returned to gm.
Also, my h3 runs perfect. Except for a couple mornings when it made loud screeching metallic noise on start up, then disipated after a very short time. Sorry I never took any pictures but I noticed that it was held on by the bolts(obviously) and some white silicone.
I never mentioned the head on collision to the repair center it never crossed my mind.
it has 104,xxx kms so just a little over 60k miles. The new motor comes from GM, with a 3 year 100k warranty for parts and labor. I will most likely continue to drive it normally as the only inconvenience is that i leave a puddle of oil on the driveway every night.
My plan is to continue to drive it until it gets bad enough that I am constantly topping up my oil level but will most likely have it done before college starts in september. Money is tight as I just turned 21 and live on my own, also tuition is hell expensive.
Sundrop Addict
Apr 27, 2010 01:12 PM
augustin01
Jun 18, 2008 06:07 PM
geeggee
35
Feb 10, 2008 03:47 PM
tjwheels
21
Jul 21, 2007 03:41 AM
HummBob
Jun 28, 2007 10:30 PM
