H3 condensation inside cab and wet carpet
Old Jan 19, 2013 | 06:17 PM
DJONES's Avatar
Question H3 condensation inside cab and wet carpet
I have a 2007 H3 and I am starting have moisture problems inside the cab. A few months ago, one of my passengers noticed the rear seat belts were wet when they buckled in (only the part of the belt that was rolled inside the side panel). More recently I started noticing a lot of condensation on the inside of the front and side windows and some condensation on the inside rear windows. Even more recently I noticed the floorboard carpet and mats are saturated with moisture. I don't do any offroading, just normal driving. Havent had this issue until recently.
Anybody out there have the same issue or have any suggestions??
Thanks in advance.
Old Jan 19, 2013 | 07:01 PM
BERULAKIDE's Avatar
My suggestion if you have a sunroof is that your drains are clogged. Do a search on here to tell you what to do and how to do it. If no sunroof i would guess roof rails are leaking.
Better to fix it fast and don't wait before it does damage to electrical.
Old Jan 21, 2013 | 07:58 PM
DJONES's Avatar
I do have a sunroof. Thanks for pointing me in the right direction.
Old Jan 22, 2013 | 04:13 PM
BERULAKIDE's Avatar
Not a problem. Hopefully it hasn't happened much. Mine leaked three times before i figured it out. Soaking the rear carpet underneath the rear seat and running down and soaking the floor right side. It wasn't the usual where it was just plugged and overflowing. My cup on the right rear had a bad seal and i gooped it up with marine goop. Works perfect now. I did the drain modding as well Bu couldn't with front cuz remote start is in the way.
just do a search and you will find everything. Hope it helps fix ya up.
NIK1
Jan 12, 2013 08:14 AM
NIK1
Dec 9, 2012 04:46 PM
dmp656
Aug 31, 2012 10:48 AM
jun_mazda
Dec 28, 2011 03:23 PM
JM
Dec 9, 2006 02:54 AM
