H3 Center Bore Question
Old Jun 21, 2013 | 08:19 AM
Neon's Avatar
Question H3 Center Bore Question
I found a set of rims for sale that are currently on a Toyota Tacoma.
I researched the rim size and found it to be:
Bolt Pattern - 6X139.7 (6X5.5)
Stud Size - 12X1.5
Hub Center Bore - 108mm
Now my problem/question is that everything looks good except the center bore.
It's larger than the 100mm that the H3 requires, but is it safe to have a rim with an oversized center bore on it??
Old Jun 24, 2013 | 07:41 AM
Neon's Avatar
Anyone???
Old Jul 3, 2013 | 02:11 PM
Happy Hummer's Avatar
JMHO
If it fits, it fits. The bore size is large enough. I personally would not choose this route but ...
Chris
Old Jul 3, 2013 | 02:12 PM
Neon's Avatar
Chris
Why would you not?
Old Jul 3, 2013 | 03:13 PM
Originally Posted by Neon
Why would you not?
The center bore is important to properly align the wheels when tightening..
Just get yourself a set of hubcentric rings (108mm x 100mm)
Benefits
- Made out of high quality Poly Carbon
- These Hub Rings are designed to eliminate vibrations caused by the wheel not centering correctly onto your vehicle's hub
- Made from plastic, so it will not corrode/rust
- Better than metal hub rings that sometimes rattle and may damage the insides of your wheels
4pc Plastic Hubrings 108mm OD 100mm ID 108mm Wheel Bore to 100mm Car Hub | eBay
Old Jul 3, 2013 | 03:16 PM
Neon's Avatar
Thanks.....I appreciate the help.
Old Jul 4, 2013 | 07:43 AM
skeeter's Avatar
I run some that are not hub centric, and I have had no problems. Everyone has their own opinion on it. Basically it comes down to do you want to run them or not.
LoJac963
Jun 26, 2014 06:44 PM
xxterxx
Jan 25, 2010 04:41 PM
xxterxx
Aug 19, 2009 11:15 AM
bluavalanchez71
Jul 20, 2009 10:44 AM
rromas00
Mar 20, 2008 05:11 AM
