H3 acuator motor
Old Nov 13, 2014 | 02:05 PM
marty22222's Avatar
Default H3 acuator motor
Anyone have info on changing the motor that controlls the 4 high lock in and out? And anyway to test it?
Old Nov 14, 2014 | 11:39 AM
Unclip electrical connector. Two bolts, remove them, remove the actuator (#12). Pull the T Case seal (#11), put in fresh seal, re-install new actuator with the two bolts.
You can test for power at the truck side connector, some have had corroded connectors, frayed or broken wires give them problems.
A squared shaft comes out of the T Case through the seal and goes into the actuator. All the actuator does is turn the shaft to shift. If they get real wet.... like when you get stuck in deep water and muck for 15 minutes +.... they puke.
Old Nov 15, 2014 | 02:32 AM
Happy Hummer's Avatar
Yep just what he posted.
Chris
Old Nov 17, 2014 | 04:28 AM
marty22222's Avatar
Thanks Doc
HummerGuy
Sep 4, 2019 12:43 PM
Ken06H3
Sep 4, 2007 08:32 PM
studio theater
May 23, 2007 07:51 PM
rtcepek
Apr 7, 2007 08:47 PM
weaponsgalore
18
Jan 10, 2007 07:25 PM
